Korg DW8000, Mono/Poly, MS-20...
Archive for DW8000.
EX 8000
EX 8000
2007-10-31 by belochim
is it possible to mod the EX8000 like a Poly 800 with for example
cutoff- and resonance mods?
Flo
RE: [DW8000] EX 8000
2007-11-01 by Andrew Wilson
I have one for sale..reasonable offers: andrewwilson434@...
To: DW8000@yahoogroups.com
Date: Wed, 31 Oct 2007 13:50:46 +0000
Subject: [DW8000] EX 8000
Flo
Sell your car for just $30 at CarPoint.com.au. It's simple!
Re: EX 8000
2007-11-01 by Chris Strellis
Sure - but why because you can control these parameters by Sysex. I
control my DW8000 using two Phil Rees C16 Midi Slider boxes:
http://www.philrees.co.uk/products/sliders.htm
Although if you do want true analogue fiddling - pots and resistors to
the cut off and resonance pins of all 8 filters is the way to go.
Then you can twiddly really quickly with no audible stepping.
However, the sysex way means you can record your twiddling in the
sequencer ;)
BTW: I Modded my Poly 800 here:
http://www.strellis.com/poly800.shtml
Cheers
Chris
Re: EX 8000
2007-11-02 by Glen Stegner
Actually, you CANNOT duplicate the Poly800 "moog slayer" mod on a
DW/EX8000 because the Poly800 only has one filter for all voices, while
the DW/EX has a single filter per voice (8 filters in all), all under
digital control. I would do what someone else already suggested, using a
MIDI slider box that supports Sysex. In fact I used to control my DW8000
using a Kenton Control Freak (before I sold it). The DW/EX8000 respond
very well to incoming sysex, filter cutoff tweaking is pretty smooth.
--- In DW8000@yahoogroups.com, "belochim" <belochim@...> wrote:
> Hi,
> Thanks,
> Flo
