are the keys on DW8000 and DW6000 the same
2006-03-08 by rover75driver
Archive for DW8000.
2006-03-09 by Chris Strellis
>I've just resurrected a dead DW8000 this (UK) lunch time - (a blown
> I know that the dw6000 isn't touch sensitive or has aftertouch but I
> wonder if the plastic keys from the dw6000 can be placed in the dw6000.
2006-03-11 by Joeri Peeters
7805 regulator for the digital side FWIW). I also modified a DW6000
recently and cleaned the keyboard contacts as well taking off all the
keys.
The DW8000 has a very different keyboard - different as can be from a
DW6000.
The 8000 has velocity and after touch and lead weights in the keys.
The 6000 has neither. They fix to the key bed frame differently and
have different springs. The 6000 is more conventional as it were with
a coil spring at the end of the key. The 8000 has a U shaped metal
strip under the key for the spring.
So in answer to your question - No - Sorry :S
Chris
SPONSORED LINKSElectronic instrument Synthesizer music Electronic music Music sampler Electronic musical instrument
YAHOO! GROUPS LINKS
- Visit your group "DW8000" on the web.
- To unsubscribe from this group, send an email to:
DW8000-unsubscribe@yahoogroups.com
- Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2006-03-12 by Mark B
> Thank you Chris for the info!
> So I don't have to bid on a cheap DW6000 on ebay.
> Joeri
> 2006/3/9, Chris Strellis <synthasy2000@...>:
>> keys.
>> DW6000.
>> Chris
2006-03-12 by manicjon
--- In DW8000@yahoogroups.com, Mark B <Bugsi@...> wrote:
> A Korg DS-8 has the same keys as the DW8000.
> But the DS-8 is much rarer than the DW8000. Still, if you find a
dead DS-8,
> you'll be in business for parts.
> -Mark
> > Joeri
> >> --- In DW8000@yahoogroups.com, "rover75driver" <joeri.peeters@>
but I
the dw6000.
blown
DW6000
all the
> >> keys.
from a
> >> DW6000.
keys.
differently and
were with
metal
> >> Chris
2006-03-13 by Glen Stegner
> But the DS-8 is much rarer than the DW8000. Still, if you find a dead
DS-8,
> -Mark
> > Joeri
> > 2006/3/9, Chris Strellis synthasy2000@...:
> >> --- In DW8000@yahoogroups.com, "rover75driver" joeri.peeters@
I
dw6000.
> >> keys.
a
> >> DW6000.
with
> >> Chris
2006-03-13 by Joeri Peeters
I think the DSS-1 also has the same keybed. Those can often be found
for very cheap esp. ones with a broken disk drive ($50 or less) and they
come up on eBay all the time, not as rare as DS-8. Those keybeds were
made by Panasonic (for Korg), they are a little on the 'noisy' side when
the key springs back in the note-off position, but the action is pretty
good.
DS-8,
> -Mark
> > Joeri
I
dw6000.
> >> keys.
a
> >> DW6000.
with
> >> Chris
YAHOO! GROUPS LINKS
