Poly 61 Battery replacement proceedure
2005-10-27 by lnz2166
Archive for DW8000.
2005-10-27 by Russell Rose
On Oct 26, 2005, at 9:51 PM, lnz2166 wrote:
> Any one have the proceedure for replacing the NiCad to Coin cell? I
> think you need to add a diode and possibly remove a capacitor.
> ------------------------ Yahoo! Groups Sponsor --------------------
> Get fast access to your favorite Yahoo! Groups. Make Yahoo! your
> home page
> http://us.click.yahoo.com/dpRU5A/wUILAA/yQLSAA/QnLolB/TM
2005-10-28 by lnz2166
> Holy Smokes, I took a chance before I got this message and justremoved R70 and replaced it with a Diode. It worked, I'm able to
>A wee bit more to it than that.
> According to Korg service bulletin for poly-61.experience.
> 1) remove R70(470 ohm)
> 2)Remove transistor Q10
> 3)Rep-lace nicad with lithium battery in same location
> 4)solder one 1N914 diode(or equiv) at location R70 and and another
> between Emitter and collector of Q10( cathode to C and anode to E)
> 5) if the CPU board is KLM475, change R146 to 2.2k ohm.
> if Cpu board KLM506 disregard R146
> pretty sure this procedure is accurate from more than one
> the diode at position R70 by the way, mounts on the PCB with itsanode
> pointecd towards Q10, cathode pointed towards(not connected) theI
> positive end of battery.good luck. Russ
> > think you need to add a diode and possibly remove a capacitor.-
> > home page
> > Yahoo! Groups Links
2005-10-28 by Russell Rose
> store programs and it holds them in memory. Thats not to say,looking
> at your email that doing it my way wont have any long term affects.
> Varta makes Nickel Metal Hydride batteried which are recharable.
> Wondering if this wouldn't be an easier solution?
> Any thoughts
> experience.
> anode
> I
>>> home page
>>> Yahoo! Groups Links
> home page
2005-10-28 by Bob Rossa
> okay. On the same service bulletin that Korg issuedhttp://us.click.yahoo.com/dpRU5A/wUILAA/yQLSAA/QnLolB/TM
> on Oct1990(for
> you history buffs)
> they also outlined battery sub procedure for the
> Poly-6, which is
> simply replacing the battery
> and removing R91(100 ohm) and putting diode in its
> place. So the
> point being why would their engineers put a tech to
> the extra work, unless there was a good reason. My
> guess is this: to
> reduce the drain current
> on the backup battery. I dont have a schematic in
> front of me but I
> guess that a precious
> amount of your battery's current is being wasted on
> forward biasing
> Q10, thereby reducing
> battery life. If you have the means check the
> refresh voltage at the
> RAM, with power off,
> should be around 2.8-3.1 volts Or check the current
> drain on the
> battery(power off)
> should be less than a coupla microamps, ideally less
> than one
> microamp. I have no
> thoughts on your other Ni-Hydride battery question
> without checking
> the specs/characteristics
> of the two batteries in question. Russ
> message and just
> worked, I'm able to
> not to say,looking
> long term affects.
> are recharable.
> > Any thoughts
> location
> R70 and and another
> C and anode to E)
> 2.2k ohm.
> than one
> > experience.
> the PCB with its
> > anode
> connected) the
> NiCad to Coin cell?
> > I
> remove a capacitor.
> Make Yahoo! your
> >>> home page
> >>> Yahoo! Groups Links
> Make Yahoo! your
> > home page
>__________________________________
> > Yahoo! Groups Links
2005-10-30 by lnz2166
>to
> okay. On the same service bulletin that Korg issued on Oct1990(for
> you history buffs)
> they also outlined battery sub procedure for the Poly-6, which is
> and removing R91(100 ohm) and putting diode in its place. So the
> the extra work, unless there was a good reason. My guess is this:
> reduce the drain currentI
> on the backup battery. I dont have a schematic in front of me but
> guess that a preciousbiasing
> amount of your battery's current is being wasted on forward
> Q10, thereby reducingthe
> battery life. If you have the means check the refresh voltage at
> RAM, with power off,checking
> should be around 2.8-3.1 volts Or check the current drain on the
> battery(power off)
> should be less than a coupla microamps, ideally less than one
> microamp. I have no
> thoughts on your other Ni-Hydride battery question without
> the specs/characteristicssay,looking
> > at your email that doing it my way wont have any long termaffects.
> > Varta makes Nickel Metal Hydride batteried which are recharable.another
> > Any thoughts
> >> between Emitter and collector of Q10( cathode to C and anode toE)
> >> 5) if the CPU board is KLM475, change R146 to 2.2k ohm.cell?
> > experience.
> > anode
> > I
> >>> home page
> >>> Yahoo! Groups Links
> > home page
> > Yahoo! Groups Links
