Korg DW8000, Mono/Poly, MS-20...
Archive for DW8000.
RE: Donucci@aol.com
RE: Donucci@aol.com
2004-03-31 by Mike Holcer
>>oh michael this is terrible
>>classic symptoms of a slidervirus
>>i had the same problem with my dw8000 exceptthat when i pressd c i got d
all
>>throughout the keyboard
>>try a little 3 in 1 oil in the tune slider
>>slide it up and down thiry or forty times to work the oil into the
>>potentiometer
>>if it seems a little fast and needs some resistance add a pinch of table
salt
>>to the groove on each side of the slider
>>the virus should begin to loosen its grip on the pitch engine immediately
as
>>you apply the oil
>>the salt will also help to eradicate the virus by turning its nucleus
inside
>>out
>>adjust the slider as you press the g key until you get a c note
>>sprinkle baby powder over the entire keyboard then push the slider back
where
>>it was
>>that should fix it good
>>hope this helps
>>whiffy winkler
What a looser as hole goof is this gay "Donucci@..." creep ?
Get a life fakface !
