Korg DW8000, Mono/Poly, MS-20...
Archive for DW8000.
Volume too loud issue - problem with Chorus board?
2012-12-02 by 7yash
My resurrected DW-8000 started having an odd problem in that its volume is way too loud. I also thought that there was some delay between pressing a key and the sound occurring.
More recently, I noticed that if I edited a patch to remove the effect completely, then I could listen to the patch at normal volumes.
Thus, it seems the Chorus board is outputting at too high a volume.
I want to fix this myself. Any pointers as to which components I should look at?
Yash
Re: Volume too loud issue - problem with Chorus board?
2012-12-06 by 7yash
Meant the effect board, which is more of a delay board actually.
Any ideas?
--- In DW8000@yahoogroups.com, "7yash" <josh.nursing@...> wrote:
> Hi,
> Thanks,
> Yash
2012-12-06 by synthjoe
I'm afraid you'll need to dive into the service manual. It is available on the net. Hope this helps.
> Any ideas?
> --- In DW8000@yahoogroups.com, "7yash" <josh.nursing@> wrote:
> > Hi,
> > Thanks,
> > Yash
RE: Volume too loud issue - problem with Chorus board?
2014-02-01 by <josh.nursing@...>
Solved it: the reason the digital effects were not being heard through the separate outs is that the mono analog signal is made into a pseudo-stereo with the digital effects board, but exactly out-of-phase, hence if there's mono anywhere in the audio path, the effects cancel out...
The DW-8000 is working perfectly.
Yash
