Korg DW8000, Mono/Poly, MS-20...
Archive for DW8000.
Korg MS20 tune problems
2012-08-27 by letcista
Hello:
I'm having dificulties in troubleshooting a tune problem on a MS20 synth.
When I press a key the note stays tuned correctly, but when the key is released, if I have VCA HOLD or RELEASE above 0, the note tunes to half tune down (If I press a C3 note, when released it assumes a B2 note).
I searched thru several posts but couldn't find anyone with a similar problem...
Freq mod knobs are set at zero.
Also:
- Jacks were reviewed and ok;
- Changed one of the VCA ICs which was dead but causing a diferent problem, not tune related;
- Changed transistor Q23, Capacitor C6 and IC5 just to check;
Q23 has 5VDC at is gate. When a key is pressed the Q23 gate's voltage drops to -1,5 VDC (wouldn't the normal be drops to zero?)
After release the key, Q23 gate gets again 5VDC.
Any help will be greatly appreciated.
Thanks!
Best regards
José
Portugal
Re: [DW8000] Korg MS20 tune problems
2012-09-24 by David Kaiser
Hello José
There is a group on yahoo which is specifically devoted to classic
(pre-MIDI) analog Korg synthesizers, it's called the KorgKornucopia.
http://launch.groups.yahoo.com/group/korgkornucopia/
I think if you ask your question in that group, you will get responses
from people much more familiar with the MS-20.
David
On 08/27/2012 03:46 AM, letcista wrote:
> Hello:
> Also:
> Thanks!
> Best regards
> José
> Portugal
