KP 60 Base Module
KP 60 Base Module
2004-02-24 by Jackie Harkins
I[m trying find out if any one else is having problems with their KP
60 base module dropping at different times,  I've tried a soft
beater then went to a hard one and I'm getting the same results
Jackie
Re: KP 60 Base Module
2004-02-24 by emf
--- In DTXpress@yahoogroups.com, "Jackie Harkins"
KP
Hi Jackie,
You have stumbled onto one of the most common and aggravating
problems with the early DTXpress kit; the archives of this forum are
littered with it. The KP60 simply did not perform well. Mine
misbehaved just like yours. I talked to Yamaha about it, opened it
up, and re-soldered every connection in sight--all to no avail.
Yamaha was very accommodating, sending me a brand new one, but the
new one wasn't satisfactory either.  Rather than go through the
frustrating process of reconstructing it, I simply switched to
another brand. I thought that the unit as a whole was a flawed design.
You can try the re-soldering process; maybe you'll have more luck
than most. If you don't want to ditch it, you could do a makeover.
Creighton Higgins, a long-time member of this group, followed
instructions from a DIY site call electronicdrums.com to create a
much more reliable kick with a larger playing surface from his KP60.
In response to another member's request to copy it, Creighton is
about to post pictures. In the meantime, you could run a search of
the KP60 in the archives (many of the posts will be mine) and/or look
there for Creighton's description of his design. Alternatively, you
could join electronicdrums and do it yourself. It's a great site in
its own right that can save e-drummers on a budget a lot of money,
though it has a small initiation fee.
Ed
Re: [DTXpress] Re: KP 60 Base Module
2004-02-24 by Ken
You don't have to join to get the plans for the modified Remo pad. Just yesterday I went to my local Guitar Center and purchased an 8" Remo practice pad for about $15. The plans call for a 10" pad but I figured the 8" would be just about right for a double bass setup. Next stop was Radio Shack for the rest of the hardware. In about 2 hours I had the thing done. Now all I have to do is modify the existing kick tower and mount it. I tested it with the snare output (2) and it is unbelievable. It feels more like an acoustic drum than the rubber pad. I will probably make another to use for the snare and use the snare pad for another cymbal. I am waiting for the photos to see how Creighton did it. The toughest part of this project was getting the piezo element out of the plastic case without "injuring" it. A utility knife, pliers, and a Dremel tool with a cutting wheel made it quite easy. If you goof it up, get another. They only cost $1.79. I bought 2 just in case.
Ken
Sent: Tuesday, February 24, 2004 8:56 AM
Subject: [DTXpress] Re: KP 60 Base Module
>; I[m trying find out if any one else is having problems with their
KP
Hi Jackie,
Ed
Community email addresses:
Post message: DTXpress@yahoogroups.com
Subscribe: DTXpress-subscribe@yahoogroups.com
Unsubscribe: DTXpress-unsubscribe@yahoogroups.com
List owner: DTXpress-owner@yahoogroups.com
Shortcut URL to this page:
http://groups.yahoo.com/group/DTXpress
Alternate DTXpress site:
http://www.dtxpressions.com
2004-02-24 by Keith
> KP
> Hi Jackie,
are
design.
I may be wrong - I haven't seen the piezos inside the drum pads, but
if you are planning to solder to them it may be wise to use a solder
with some silver in it.  I read somewhere that where the electrodes
are silver (rather than nickel) then using just a lead/tin sodler can
remove the silver plating.  I can confirm this is true because I have
seen the plating disappear when I used ordinary solder! (but not on an
e-drum).
Keith.
2004-02-25 by alex sobolev
does the same trigger problem exist with the dtxII?
Do you Yahoo!?
Yahoo! Mail SpamGuard - Read only the mail you want.
http://antispam.yahoo.com/tools
2004-02-25 by emf
--- In DTXpress@yahoogroups.com, alex sobolev <xelavelobos@y...>
Alex,
Apparently not. A comparison of the number of complaints generated by
the KP60 vs. those for the 65 would suggest that the problem didn't
persist into the new generation.
Ed
2004-02-26 by joe69128
Im also very interested in doing this for that exact purpose.  And
hoping to get a slightly better feel out of the kick pad.  How much
was it for all the parts, i have the tools mentioned. .
2004-02-26 by Ken
Remo 8" tunable practice pad was $15 at Guitar Center. (make sure you get the Remo)
Check it out here
Piezo was $1.79 at Radio Shack.
RCA jack was $3.99 (I think) for a pack of 4 at Radio Shack.
I used 2 pieces of 1/2" thick foam that I had on hand. When you take it apart, there is only one 1/2" piece of foam in there but the two piece "sandwich" fits well. It's tight but I think that makes for the great feel and rebound when used as a snare.
Ken
Sent: Thursday, February 26, 2004 12:00 AM
2004-02-27 by bparker0701
What density of foam is best?  There's vacuumed foam that is
extremely dense and heavy.  This might give a "tight" feel/high
response, whereas less-dense-foam would yield visa versa.  I'm mostly
interested in replacing the kicker pad on my KP65 (wore through front
before putting Kevlar patch on it).  Don't think I want high bounce
on my kicker.  Electronicdrums.com said to use the same as Remo, but
I don't know Remo's foam.
Bill
you get the Remo)
> Check it out here
http://www.musiciansfriend.com/srs7/search/detail/base_id/39114/src=00
631
> Ken
2004-02-27 by Ken
The foam I used is a synthetic type used for seat cushions. Closed cell and quite "mushy". When 2 thicknesses of 1/2" are squeezed in under the head, the rebound is perfect.
Ken
Sent: Friday, February 27, 2004 12:38 PM
Bill
you get the Remo)
> Check it out here
631
> Ken
2004-02-28 by Nick Carroll
KP
> Jackie
I had this same problem at band practice the other day - I fixed the
problem by flicking the switch on the tower from "B" to "A"
Polarity. It fixed it immediately, and I got a better sound as well.
Nick.
