thanks for the reply ed,
all i currently have is a dtxpress(I), and i want to run all the
existing pads plus a hart pro snare and a few visu lites through a
dmpro brain. i'm assuming that this should be possible. please bear
with me on this next one as i'm not 100% clear on the differences
between stereo and mono pads, at least i'm not sure if i know or not,
if u know what i mean.
are stereo pads pads that can trigger more than one sound? if that is
the case then that makes my TP80S and PCY80S stereo pads, so dual
pads is another way of saying stereo pads, am i on the right track
here?
so by using a brain (such as the dmpro) that only supports mono
(single) inputs means that all of the pads i use (mono or stereo) can
only trigger one sound, is this right?
if this is the case then i could trigger any dual (stereo) pads, like
the hart pro snare and PCY80S, through the dtxpI which does support
stereo pads, and all the other pads through the dmpro. does this make
any sense or have i just got the fundamental difference between
stereo and mono all wrong here?
cheers pete
--- In DTXpress@yahoogroups.com, "liberatusvirus"
<liberatusvirus@y...> wrote:
> --- In DTXpress@yahoogroups.com, "peterpan" <malakies2000@y...>
wrote:
> > finally about to upgrade my existing edrum setup, am considering
> > using the dmpro as my main brain unit. only problem is i have
many
> > yamaha trigger pads from my dtxpress which i intend to
> > use, and i dont know anybody who uses the dmpro with yamaha pads.
> > firstly, is this possible? (i'm assuming it is) and secondly, for
> > those of u who have tried/use this configuration, does it work
well
> > or have u encountered any problems? was there any need to buy
> > additionals accessories (i.e. cables etc)?
> Hey Pete,
> You can get the DM Pro really cheap now. I've seen it on ebay for
> $450 or so with Buy It Now. Considering what it is, it's a genuine
> temptation. Caveat: I've seen reports that its reliability is
> suspect. Whether the price drop is due to the company's
misfortunes,
> an impending face lift, or quality-control problems, I don't know.
So
> far as the Yamaha pads are concerned, the Pro is mono-input only.
It
> is not compatible with the so-called "stereo" gum rubber pads--
piezo
> plus rim switch(es)--that Yamaha, Pintech, and Roland feature; it
> turns them into single zones. If you've got a heavy investment in
> stereo pads, the DM Pro might not be for you. It does have a fully
> variable hi hat function, however. I'll let somebody who uses the
Pro
> with Yamaha pads go into the tweaky details. But if you have a
Guitar
> Center anywhere nearby, you might be able to connect a Yammy pad
and
> see firsthand. GC also might give you a good price; I think they're
> trying to unload product these days.
> Ed
