Labeling cables...
Labeling cables...
2003-08-11 by Stephanie Ellison
Just got an idea here!
Stephen (was that you?), I have an idea on how you can label the pad input
cables neatly.  You'll need a labelmaker (the one with a handle and a round
thing that takes that plastic tape and you click out letters and such) and a
soldering iron with a clean, non-oxidized tip.
Make the labels long enough to overlap a bit on the ends.  Once you've done
that and you have the labels on currectly, carefully melt the overlap and the
underlap together carefully.  They shouldn't come apart that way.
I bought a set of 5 different colors of tape, so that they are color-coded for
finding both ends and numbered so that you can quickly plug the cable into
the right input jack.
Stephanie with an idea...
RE: [DTXpress] Labeling cables...
2003-08-11 by rdamon@mckinney-usa.com
> for
> Yes, label makers are great. I used it to organize all the cables on my
> set.
OGD
The information transmitted herewith is sensitive information intended only
for use to the individual or entity to which it is addressed. If the reader
of this message is not the intended recipient, you are hereby notified that
any review, retransmission, dissemination, distribution, copying or other
use of, or taking of any action in reliance upon, this information is
strictly prohibited. If you have received this communication in error,
please contact the sender and delete the material from your computer.
________________________________________________________________________
This email has been scanned for all viruses by the MessageLabs Email
Security System. For more information on a proactive email security
service working around the clock, around the globe, visit
http://www.messagelabs.com
Re: [DTXpress] Labeling cables...
2003-08-11 by Vernon Graner
I use these:
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F011%5F010%5F008%5F001&product%5Fid=278%2D1616
Go to Radioshcak.com and search for catalog # 278-1616
These are little stick-on labels that you write on with a fine-point
sharpie and they look *very* pro and have proven to be very durable since
they don't stick to get in the way or get torn off.
You peel it, start to wrap the cable, write the text, then wrap the rest
of the way. It's kinda like a 4 inch pice of very strong tape with the
first inch opaque white and the rest is clear, so you wrap the white
part, write the text and then cover it with the remaining clear tape to
protect it. The ones I have haven't gotten "gummy" yet and it's been
about a year.. YMMV :)
Vern
Vern Graner CNE/CNA/SSE     | "If the network is down, then you're
Senior Systems Engineer     | obviously incompetent so why are we
Texas Information Services  | paying you? Of course, if the network
vern@... www.txis.com  | is up, then we obviously don't need
Cell 507-7851 Desk 328-8947 | you, so why are we paying you?" VLG
> input  cables neatly.  You'll need a labelmaker (the one with a handle
> and a round  thing that takes that plastic tape and you click out
> letters and such) and a  soldering iron with a clean, non-oxidized tip.
> done  that and you have the labels on currectly, carefully melt the
> overlap and the  underlap together carefully.  They shouldn't come
> apart that way.
> color-coded for  finding both ends and numbered so that you can quickly
> plug the cable into  the right input jack.
> ---------------------~--> Low on Ink? Get 80% off inkjet cartridges &
> Free Shipping at 77Colors.com. We have your brand: HP, Epson, Lexmark,
> Canon, Compaq and more!
> http://www.c1tracking.com/l.asp?cid=5981
> http://us.click.yahoo.com/DmnqpB/IyhGAA/ySSFAA/kkLolB/TM
> Community email addresses:
>   Post message: DTXpress@yahoogroups.com
>   Subscribe:    DTXpress-subscribe@yahoogroups.com
>   Unsubscribe:  DTXpress-unsubscribe@yahoogroups.com
>   List owner:   DTXpress-owner@yahoogroups.com
> Shortcut URL to this page:
>   http://groups.yahoo.com/group/DTXpress
> Alternate DTXpress site:
>   http://www.dtxpressions.com
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
One thing I forgot to write is that the label go on the cable plug itself and
not the cable itself.
Stephanie
Re: Labeling cables...
2003-08-11 by oldguydrummer
--- In DTXpress@yahoogroups.com, Stephanie Ellison <deafdrummer@a...>
itself and
> Stephanie
Wouldn't it be nice if the cables came from Yamaha pre-labeled? The
label could be molded into the connector, so you would have one end
labeled snare the other end zone 2.
Since labeling of cables is a universal issue, why haven't cable
manufacturers come up with a snap on device that would attached at
the plug end (between the cable and the connector plug/jack) that had
a flat white write-on surface of say 1/4" high x 1" long. The flat
surface could be placed on two sides, for more writing area.
OGD
2003-08-11 by liberatusvirus
had
The twiddly audio/video people frequently attend to such matters. I
know that Monster supplies stick-on labels for the cables that
connect to their AC line filters. Try AudioAdvisor, for example, for
something that might be adaptable. Incidentally, an AC line
filter/surge protector might be a good idea to use with a drum
module.
Re: [DTXpress] Re: Labeling cables...
> module.
How about this - a UPS (Uninterruptible Power Supply) commonly used for
computers?  Not only do you have your surge and lightning protection, but
you've got brownout, spike, and AC line noise protection, along with a
conditioned, steady power supply that keeps going after the power goes out,
long enough to reach the end of a song.
Has anyone tried this and how big a UPS do you have to get in order to keep
playing until the song is over?
Stephanie
2003-08-12 by brown8700
My method for labeling cable is such:
I wrap the ends of all cables going to module A in red electrician's
tape. All the cables going to module B are wrapped in yellow tape.
I then place 1/2" stick-on letters on the tape. On one end, I label
the trigger number. On the other, I label the pad type by initial
i.e. S=snare, T1=Tom 1, HH=Hi-hat, etc. T
his seems to work quite well for fast set ups.
Stephen
2003-08-12 by hairytrigger
Here's my $.02 on the labeling issue:
Mine ar not labeled. I leave the cables plugged in to the module. The
cables are neatly bundled into a harness, with the appropriate cable
exiting the harness at the proper position. Once all the pads are
mounted, I mount the module, lay out the harness, and just plug them
in. I have never gotten it wrong. The only disadvantage, is with
spiral wrap, changes are difficult (it takes a long time to
wrap-unwrap). Make sure you have the set-up you want before you
harness.
I use a large diameter wrap at the module, and a smaller one once some
of the cables are out. There is one branch in the harness that runs
down the left vertical tube that carries the kick and HH foot control
cables down to the floor.
There is a different type of wrap i saw once on an infomercial that
was very easy to wrap and unwrap, but i have not seen it since. I
don't like the 'corrugated' split type tubing. It seems to cut into
the cables.But it is easier to wrap.
The harness keeps the cables tightly bound together, and is almost
invisible when properly positioned.
Scott
> Stephen
RE: [DTXpress] Re: Labeling cables...
2003-08-12 by rdamon@mckinney-usa.com
> Stephanie wrote: "Has anyone tried this and how big a UPS do you have to
> playing until the song is over?"
Stephanie,
I have a 1000va UPS that I use for computer/drums/etc. Because I don't use
everything that is plugged into the UPS at one time, it works great.
If you consider that the my three modules only use that  12watts, the mixer
less than 50watts, and the KC500 about 210watts,that all I really needed was
a 350VA unit. The UPS literature will tell you the battery time for fully
load and half load. Most UPS with give at a mininum of 15 minutes.  Now days
for under $100 you can get something that is more than adequate for your
needs.
OGD
