Re: [DTXpress] Re: another New Owner
2000-09-16 by Sanctum
Hey, Bill Percussion sounds, cowbell and wood block included are in the DTXpress brain just highlight the first letter of the voice description (K for kick drum S for snare etc) you can change this manually getting to the percussion section, and there you go lots of percussion noises to add to your kit. I suggest the T bar because it's a small dual zone pad (both piezo triggers, not rim and pad) which is most at home as a wood block, cowbell or other percussion simulator as opposed to a pad which more suits a drum. No real big differences except size shape and feel. Hope you work things out, keep posting your problems, we're all quite happy to help where we can -----Original Message----- From: Bill <groovinbill@...> To: DTXpress@egroups.com <DTXpress@egroups.com> Date: 15 September 2000 16:01
Subject: [DTXpress] Re: another New Owner > >Thanks Sanctum - >I'll try the voice edit options and experiment with the two sounds. >That's certainly more economical than a dual zone pad. As for adding >accoustic percussion, I am not familiar with the T-bar trigger from >Yamaha. It's probably mentioned somewhere in the archives so I'll >look. I assume it provides the ability for cowbell, etc. sounds. >Price isn't a concern. > >Thanks again for your advice. > > > >Community email addresses: > Post message: DTXpress@onelist.com > Subscribe: DTXpress-subscribe@onelist.com > Unsubscribe: DTXpress-unsubscribe@onelist.com > List owner: DTXpress-owner@onelist.com > >Shortcut URL to this page: > http://www.onelist.com/community/DTXpress >
