Buzz rolls on mesh pad
2003-06-21 by Stephanie
Hi Everyone:
I hope someone can help me out here...  I have the DTXpress II brain on my
kit, and I've been trying to resolve a problem with my playing buzz rolls on
a home made mesh drum pad.
I have it plugged into the Tom 3 plug, which has the TP65-2 trigger setup by
default.  When I try to do a buzz roll, I get a lot of sound dropouts, like
the set up can't keep up with the data flow or something.  When I try
different trigger setups, (as in shift-trigger edit, user trigger set up #7)
like DT Snare or DT hi tom, the sound is even worse (probably because of the
parameters, and I know I'm not supposed to use these for a mesh pad).
I wonder about the "misc 1-6" pad types - anyone know what this is for?  I'm
trying to find a setting that will allow for clean buzz rolls on a mesh pad.
Thank you!
Stephanie
Re: Buzz rolls on mesh pad
2003-06-22 by liberatusvirus
brain on my kit, and I've been trying to resolve a problem with my
Hi Stephanie,
I don't know whether I can help, but I'll try. The ultimate answer
may lie, at least to some extent, in the physical characteristics of
your homemade mesh pad. What kind of trigger are you using? Do you
have the piezo inside a foam wedge (like the Pintechs) or inside a
foam cone (like the Rolands)? Is the mesh head touching the foam
cover, clamping down as you tighten? We'll leave these questions
aside for now and tackle the module.
trigger setup by
dropouts, like
The easiest solution would be that, whatever trigger setting you're
in, you simply have your min. velocity setting too high and/or your
gain too low. If tinkering with those settings gets you back in the
game, then you're done, though I don't think that the TP65 defaults
are ultimately your best bet. Another setting to check is self-
rejection; if that's too high, some of the buzz hits will drop out.
Lower it until the problem goes away.
> When I try different trigger setups, (as in shift-trigger edit,
because of the
pad).
Just for the record, my kit is comprised completely of mesh pads,
and I use the DT trigger settings for all of them individually, as
well as the global one. I get buzz rolls, pressed rolls (on my
snare, anyway), etc. You name it; I get it with these settings. In
other words, my electronic kit is programmed as if I were triggering
acoustic drums.
for?  I'm
mesh pad.
I can't tell you exactly what Yamaha was thinking when they added
the misc. settings, but if your problems persist after you try the
suggestions above. By all means, give the relevant misc. options a
go, one by one. For example, I've found that the misc. cymbal
settings are the most responsive for my Visu-lite cymbals, though
they don't make a world of difference. If, in the end, nothing is
working, and nobody else comes up with any suggestions, we may have
to look more closely at your mesh heads and triggers.
Ed
Re: [DTXpress] Re: Buzz rolls on mesh pad
2003-06-22 by Stephanie
It has a Radio shack piezo tranducer on top of a piece of foam, with a Roland
foam cone on top, and it was designed so the cone would touch the mesh head
just before the mesh head would sit on the bearing edge, so the cone has good
contact with the head.
Here's what I did - My guess it might have to do something with the pad type
setting for the trigger input.  When you go Shift-Trig Edit and go to 7 (for
a user trigger setup), you can select the pad type.  I tried the RHP-pad
(which is for a mesh head type pad), but there were too many gaps in the
sound of the buzz  roll.  The DT series settings were even worse.  I went to
the misc-1 pad setting and bumped the gain all the way (to get THE most
sensitive setting.  With this, just barely touching the pad with my finger
would trigger the pad).  I was able to get a coarse buzz roll pretty good,
and I wasn't able to tell if it's my playability or the setup making it sound
a bit uneven, but it sounded a lot better.  I couldn't tell if there were
drop outs with a finer buzz roll (remember, hearing's not that good).  I go
after this because I had a dream one night in which I was playing a buzz roll
on a snare drum.  I was really roiling over the drum head, and it sounded
perfectly even.  That must have gone on for about 7 seconds.
Thanks!
Stephanie
WHAT is rejection - self rejection - specific rejection?  I tried to read the
manual, but it doesn't seem to translate for my computer networking brain...
Thanks!
Stephanie
2003-06-23 by Stephanie
> yourself a little more leeway, have you tried setting the DIP
> switches on the back of the module, corresponding to inputs 1-6 (or
> at least the one for input 3), at the high setting? That strategy
> might well get you a sensitivity boost without the risk of excessive
> gain.
Yep!  I did that a couple of days ago,  and that didn't seem to change the
dropouts much.  I still have it on there, though, but I use the very high
gain setting on that pad in a user trigger setup for snare drum practice.
When I'm playing my drum set, I go back to the dynamic trigger setup.
Thanks!
Stephanie
2003-06-23 by liberatusvirus
> I went to
most
my finger
pretty good,
making it sound
One more suggestion. It sounds like you're well on your way to
reaching buzz nirvana. I'm pretty sure that you'll be able to get
even strokes. But bumping up gain too high can have dire
consequences (crosstalk, self-choking, machine-gun effect). To allow
gain.
Ed
to read the
networking brain...
Stephanie,
The short version is that the rejection parameters keep crosstalk
between pads, and within a single pad, at bay. What the rejection
setting per se does is mute a pad for a split second while an event
on any another pad is taking place so that the former won't reach
sympathetically to the latter. For obvious reasons, rejection
settings should be only as high as it takes to keep particular
reverberations along the rack from making extraneous noises; muting
pads is definitely not the reason why we bought these things. Self-
rejection is protection against a pad's triggering itself (most
likely when sensitivity is too high)--in other words, double
triggers; specific rejection is the way that one pad protects itself
from a particular pad's reverberations. Again, if you were to notice
a problem (like the hi hat keeps tripping the snare), you would set
the snare's specific rejection to the point at which the problem
stops, but no higher. A pad's high specific rejection setting almost
guarantees that it will not make a noise when hit at the same time
as its offending counterpart, since the higher the setting, the
smaller is the window of opportunity of that pad to make a sound
when you want it to. I know that even this short version is
confusing, but the long version is even more complicated. We can
delve into it more if you need to.
Ed
