What are the differences between the TP65 and TP80 pads?
2003-01-28 by underneathheaven <realvast@swbell.net>
My dtxII came with all the pads as either a 65 or 65s.  The DTX
comes with those 80 or 80s pads.  Are they much better?  What do
they feature that the 65s dont?  I'm just wondering if they are a
sound investment.  Also, I heard someone mention the HH80 was also
better.  Why is this?  Does it respond better?  If it does I'm
buying it!
Re: What are the differences between the TP65 and TP80 pads?
2003-01-28 by liberatusvirus <liberatusvirus@yahoo.com>
Aren't the TP65s pads the ones with the three sounds? The TP80s has
only two. I would assume that the non-"s" versions are mono.
Otherwise, the two model numbers probably aren't too different from
each other (though some places might be selling the 80s for more
because they listed for more). The HH80a is the definitive Yamaha hi
hat pedal, at least until the next generation, because it captures
the full range from open to close. The 60 and 65 only get fully
open, fully closed, and a mid-point.
--- In DTXpress@yahoogroups.com, "underneathheaven <realvast@s...>"
> buying it!
Yes the 65s do have three sounds and the 65 are priced lower than
the 80 series pads.  OK Ill stick with the 65 and 65s, but the HH80
seems to be a good investment though right?
--- In DTXpress@yahoogroups.com, "liberatusvirus
has
from
hi
<realvast@s...>"
a
also
> > buying it!
The HH80 is the way to go, unless you are interested in the upcoming
Visu-lite hi hat assembly, which will be based on it.
HH80
> has
> from
Yamaha
> hi
captures
> <realvast@s...>"
DTX
do
are
> a
> also
> > > buying it!
