DTX2 on pc
DTX2 on pc
2002-07-28 by moumoucheee
Hello,
im new to this group and a new user of the yamaha dtxpress. Ive just
bought a dtxpress 2, and tried to download some sysex from this
groups to the dtxpress2, it doesnt work. Ok. (ive just seen a message
about the "incompatibility")
But the thing who is boring me, is that when im trying  to upload
files from mod to pc with DTXchange  : it doesnt work neither. (there
s no message on the dtxpress, just like if it wasnt plug to my pc)
So i just wonder if it is possible to use dtxchange with the
dtxpress2. or maybe (...probably) i missed something in midi setup or
something else.
Moumouche
Re: DTX2 on pc
2002-07-29 by ozteevan
Hi Moumouche
Giles confirmed in post 2144 that the DTX and the DTXpress use sysex
files that are not compatible with each other.
I found that using the Midi Monitor utility which is available on the
group Files area at
http://groups.yahoo.com/group/DTXpress/files/Utilities./midim201.zip
to be very helpful when first setting up my PC link.
Check to make sure that you have the midi cable attached to your drum
unit correctly --> IN goes to OUT and OUT goes to IN <--
Roger
--- In DTXpress@y..., "moumoucheee" <balk@i...> wrote:
> Hello,
just
message
(there
or
> something else.
> Moumouche
Re: DTX2 on pc
2003-02-16 by dawsonmcshane <dawsonmcshane@hotmail.com>
I also have a DTXpress 2. I am using a joystick cable to my sound
blaster live card. I have tried DTXchange but I have had no response
whatsoever. Let me know if you have any tips. Thanx,
--- In DTXpress@yahoogroups.com, "ozteevan" <ozteevan@y...> wrote:
> Hi Moumouche
sysex
> group Files area at
drum
> Roger
> > Hello,
> just
> message
upload
> (there
pc)
setup
> or
> > something else.
> > Moumouche
Re: DTX2 on pc
Well after reading prior posts I have solved my problem. My problem
was I had my midi cables crossed. I had In going in and out going
out.This is incorrect. I swapped them and I can send and recieve.
DTXchange works great. I am using XP os. good luck.--- In
DTXpress@yahoogroups.com, "dawsonmcshane <dawsonmcshane@h...>"
response
> > Hi Moumouche
> sysex
on
> the
> > group Files area at
> drum
> > Roger
> > > Hello,
Ive
> > just
this
> > message
> upload
> > (there
> pc)
> setup
> > or
> > > something else.
> > > Moumouche
