Ecymbal II crash cymbals
2002-06-22 by Glen Davidson
Ecymbal II review.
I just received a Hart Ecymbal II 14" crash cymbal and have a 12" crash on the way.
When I took it out the box I was a little disappointed. I was under the impression from what I had been reading that this was a real metal cymbal with a coating over it to make it quiet. Well it's not, It appears to be plastic with a gold foil type covering on it. It feels a little flimsy.
I mounted it on my DTXpress kit with the supplied cymbal spring and started banging away. The first thing I noticed is that the cymbal is extremely loud when hit. I also noticed that the gold foil covering started to chip on the edge of the cymbal from being hit with the stick.
To my surprise the cymbal played excellent, it triggers perfectly and acts and feels like the real thing. It also looks great. I ended up taking the rubber off of a pcy 60 pad and put it on the ecymbal to dampen the noise. That worked out very well. It did hot affect the triggering at all and reduced the noise to about the same as the pcy 60.
Positives:
- Triggers and tracks extremely well
- Looks and acts like a real cymbal
- easy to set up with not much tweaking with DTXpress module
- looks great with the DTX kit
Negatives:
- very loud with out a rubber pad on it
- gold foil covering chips easily on edges
Over all:
It's a great addition to my kit. It triggers and tracks much better than the pcy 60 or 80. It has a real feel and look when played. Hart really needs to add the rubber pad on the crash ecymbals as they do on the ride and the high hats. A rubber strike zone eliminates the noise and reduces the chipping on the edge of the cymbal. Over all thumbs up!! It's a great product.
Glen
