> it sounds like that it may be the gain is set too high or maybe the m-
> velocity if these are set to high then a pad with the high settings
> will most likely trigger randomnly when you're playing another pad
> (had this happen with my concertcasts) a good trick is to push the
> voice button on your module,and go ahead and start playing your snare
> like you would normally play it,then watch the readout on your module
> for what pad is being triggered while playing,then when you hear the
> tom sound that you said you've been hearing you should know what pad
> it's coming from,and then go in to the settings for that pad,and
> reduce them(ex.gain,m-velocity,etc.) until you see which one works
> out) or if you're using a stereo pad and the tom sound is being
> produced from the snare pad ,and not another pad on your kit,you'll
> need to eliminate the tom voice setting for the snare pad
> hope this helps,
> sam(otacon28)
> --- In DTXpress@y..., "Jay Welch" <jay@s...> wrote:
> > I have a problem that has just started. My snare will randomly
> produce another drum sound. I have tried to count and see if there
> is any pattern but it just seems random. It produces a tom
> sound. It seems to do it on several kits. I have only or two or
> three kits I use a lot so I have not tested them all. Has any one
> had this problem or know what it may be?
> > Regards,
> > Jay
> Community email addresses:
> Post message: DTXpress@onelist.com
> Subscribe: DTXpress-subscribe@onelist.com
> Unsubscribe: DTXpress-unsubscribe@onelist.com
> List owner: DTXpress-owner@onelist.com
> Shortcut URL to this page:
> http://www.onelist.com/community/DTXpress
