snare upgrade
snare upgrade
2011-11-18 by i
hey edrummers,  check youtube...... impossible drum solo hq.....my question is has anyone stepped up the snare on the xpress lV to a tp100? and is it worth it ?  thats the 10 inch with adjustable snare wire
Re: snare upgrade
2011-11-18 by alfredoxpress
I did four months ago and believe me it's totally worth it. The feeling of the pad is different and having the red knob to adjust the snares is a plus. I have placed my tp100 on a snare stand.
Re: snare upgrade
2011-11-21 by denim_demon2003
Me too. I then changed up again to the tp120 which is the 12" snare. On a stand. Brilliant. Well worth it.
Havn't posted for a while, anyone in UK, or Europe, who wants to sell a tp65s drop me a pm.
Re: [DTXpress] Re: snare upgrade
2011-11-21 by Andrew Willis
Thanks for all the comments, the tp100 and tp120 sound a great upgrade.
Anyone have any specific experience of plugging them into a DTXPress I?
I'm aware they will work without supporting all the different sounds, but still worth it?
In a similar vein, does anyone recommend / have comments on the RHH130 or the RHH135 hi-hats and which one to go for?
Many thanks in advance
Andrew
On Mon, Nov 21, 2011 at 3:11 PM, denim_demon2003 <denim_demon2003@...> wrote:
--- In DTXpress@yahoogroups.com, "alfredoxpress" wrote:
> I did four months ago and believe me it';s totally worth it. The feeling of the pad is different and having the red knob to adjust the snares is a plus. I have placed my tp100 on a snare stand.
Re: snare upgrade
2011-11-21 by keith1200rs
--- In DTXpress@yahoogroups.com, Andrew Willis <ajw3371@...> wrote:
> Hi,
> still worth it?
I use the TP100 on my DTXpress III on a snare stand and much prefer it to using the smaller pads attached to the rack.  No crosstalk, bigger pad, better positioning.
Keith.
Re: snare upgrade
2011-11-24 by denim_demon2003
Yo. I have a rhh135. It is great fun, especially if you have the yamaha stand to go with it. Tried it on a cheap generic stand and it was awful.
It is a great upgrade if, like me, you like it to play like the real thing. Before, I used a roland cy5 cymbal with the yamy pedal as my hi hat and that worked perfectly well and is a good cheap option.
I don't know how compatible the rhh135 is with a dtxpress I so maybe Keith can answer that for you.
The rhh135 is a dual zone cymbal, I don't know if the 130 is.
I think the main difference is the 135 behaves like a true hi hat with the 130 the movement is internal so the pad itself does not move up and down. I love it for that reason. It does tend to spin a little on the stand which is a trifle annoying and would probably piss me off if I was gigging it.
Hope that helps and keep asking questions.
Cheers
> Hi,
> still worth it?
> Andrew
Re: snare upgrade
2011-11-24 by keith1200rs
All I can say about the RHH135 compatibility is to let you know what it says in the RHH135 manual - I have no direct experience of the RHH.  It is a good match for the DTXpress III/IV, according to the manual.  For the DTXpress I/II it gives the recommended settings for HH Offset, velocity & gain.
Keith.
2011-11-27 by Andrew Willis
Many thanks all.
In case others haven't seen it, this link is invaluable for considering next upgrades.
The RHH135 sounds pretty good - that combined with a larger snare on it's own stand sounds a good way to go.
Cheers
Andrew
Keith.
