Triggering voices on and off
2011-01-05 by Chris
I put together a multipad and am trying to figure out how to make a continuous sound (such as Synth or Strings) start when a pad is hit and then stop when a different pad is hit (while also triggering the next voice...
Setting up a xylophone or marimba is easy because the sounds decay but this has me baffled....
I didn't see anything in the manual that covers this situation.
Re: Triggering voices on and off
2011-01-05 by keith1200rs
Chris,
You need to set "Hold Mode=ON" in the voice settings.  I think it will only work with the loop voices - L.  For example look at some of the quirky kits - usually the higher numbers above 23 or so.
Keith.
2011-01-06 by Chris
Keith,
Thanks, I'll try it out.
--- In DTXpress@yahoogroups.com, "keith1200rs" <keith@...> wrote:
> Chris,
> Keith.
