--- In DTXpress@yahoogroups.com, "ostin67" <ostin@...> wrote:
> Hi. Sorry if this has been discussed before but can anyone inform me if I can use a Roland Pad with my DTX3 or my DTX4? I was thinking of the PD 6, 7 or 8? Many Thanks
Most manufacturers pads will work with the DTXpress modules. You may need to change some module settings to get the best out of the pads and sometimes a resistor across the pad can be helpful (eg with a Pintech Concertcast which produces quite a large signal). I think the PD6,7,8 are piezo/switch type, so you should be ok. Dual piezo ones can be more tricky to get both sounds, but it can still be done.
Keith.
