Low Battery Warning
Low Battery Warning
2010-02-19 by Stimpy_bum
Hello all I have a DTxpress and it's warning me about low battery. Can I change this myself. How do I fix this problem? Thanks.
Re: Low Battery Warning
2010-02-19 by keith1200rs
Yes you can do it yourself.  I think its a CR2032 but I am not sure.  I found this in the archives:
"Remove two screws on each side and one on the back and slide the case off toward the rear of the module. It is a button style battery that is easily accessed and replaced."
Back up your kits first - you will lose them.  Someone recently did it with the power on (EEEK!) using a wooden toothpick to avoid losing the settings but I wouldn't recommend that!  I did a search and found someone who did the same thing in 2003 - it is post 3133 if you want to have a look.
There are a couple of pictures of the inside of the module in the photos section.
Keith.
