Drop Clutch
2009-09-10 by cbarnhart44
You could assign a pad to swap the sounds from open to closed Hi-hat when struck (or change to user defined kit with the hi-hat in the closed position). "I want to electronically add the facility of a drop clutch to get a 'closed'sound from the hihats when the hihat pedal is released, and to restore the hihat to 'normal use' on the next press of the hihat pedal."
