computer drum software only triggering piano sounds on dtxpress iii?
2008-05-16 by tim_verry
I use Tracktion 3 and a VST plugin called Jamstix which sends drum
data out via midi.
The problem is that the dtxpress iii module only produces piano sounds
in response.
There doesn't seem to be any changes in the software that are
relevant, do I have to change something on the module every time I
want it to play a specific kit in response to the drum software?
RE: [DTXpress] computer drum software only triggering piano sounds on dtxpress iii?
2008-05-16 by Jonathan Wilkinson
You might want to change the midi channel to 10.
To: DTXpress@yahoogroups.com
Date: Fri, 16 May 2008 13:26:30 +0000
Subject: [DTXpress] computer drum software only triggering piano sounds on dtxpress iii?
data out via midi.
in response.
Messenger's gone Mobile! Get it now!
