factory setting
factory setting
2008-03-25 by scott Richardson
Can anyone tell me how to reset the DTX3 back to factory setting.  My Hi-Hat
sounds like a bass drum and I can't change it
Scott
Re: factory setting
2008-03-26 by Keith
--- In DTXpress@yahoogroups.com, "scott Richardson" <akascottdr@...>
My Hi-Hat
Scott,
Hold the page up & page down buttons when turning the unit on (see
page 32 of the user manual).
An alternative seems to be to use the "UT System Factory Set" menu -
see page 31 of the reference manual.
Keith.
Re: factory setting
2008-03-27 by Tom Watson
You know, what you're describing sounds like what my rhh130 was doing
when I first hooked it up to my dtx1... couldn't get a consistent
open high hat sound, sometimes it was a closed hi-hat sound, and
sometimes something else.
It didn't work right till I reset the dtx 1 to the factory
settings(page 29 of the manual) and viola! it worked perfectly! watch
out though it resets "everything" to factory settings!
I'm beginning to think that any changes you make to the dtx need to
be noted in a little book and then reset it to factory spec and
reprogram them in whenever there is a problem! This may make it work
proper!
Tom
My Hi-Hat sounds like a bass drum and I can't change it
Scott,
Keith.
      __________________________________________________________________
Looking for the perfect gift? Give the gift of Flickr!
http://www.flickr.com/gift/
Re: factory setting
2008-03-27 by Keith
If you do have the RHH130 and do a factory reset, you will need to
change the trigger settings for the hihat afterwards - the default
setting doesn't assume the RHH.
Keith.
