--- In DTXpress@yahoogroups.com, "m_hanscom57" <m_hanscom57@...>
wrote:
> After reading a posting here I was finally able to located the GM
> voices and I found a nice bell sound I need tomorrow for Hark The
> Hearld Angels Sing. However, the volume of the voice is very, very
low,
> even when I set it to max of 127.
> Also, as soon as I save the kit, the entire character of the bell
sound
> changes to something totally unacceptable. Can someone please
advise me
> on this?
> Thanks for the help, Mark.
Mark,
I've forgotten more about the Yamaha kits than I have any prospects
of regaining. But I can tell you that you can adjust volume not only
on individual pads but also in a global setting buried somewhere else
in the menu system, depending on which version you have. Settings
other than volume can affect loudness, too, like gain and resistance.
If I'm not mistaken, some of the voices are also weaker by nature
than others. But, all in all, you should be able to squeeze more out
of what you have.
So far as losing your GM voice when you save a kit, since the note
numbers assigned to kits are determined by the particular pad within
the kit, not by the particular voice, the kit may default to a
standard voice when saved. I'm not sure. Sometimes you have to assign
an unused note number manually to a voice to make it stick on that
pad. If I could recall how to do it, I'd let you know, but maybe one
of the more current members will set you straight--if that's even the
problem.
Ed
