DTX III Snare Pad sending multiple triggers
2007-04-10 by Jake Kurdsjuk
All of a sudden my snare pad is triggering both the center and the rim
shot zones when the pad is struck in the center.  This holds true for
the 2/3 of the pad closest to the rim trigger.  The other edge trigger
is operating normally.  It's almost as if the trigger has slipped off
the rim and is now picking up center strikes.
Is this something that I can fix?  Can I open the pad up and take a
look?  Help!!
Re: DTX III Snare Pad sending multiple triggers
2007-04-10 by Keith
> look?  Help!!
It sounds like a connection problem.  Try another cable first, just to
eliminate that.
There are pictures of the all pads in bits in the photos section
(thanks to oldguydrummer) so you can see what is inside before you
start - assuming it is out of warranty.
Keith.
Re: [DTXpress] Re: DTX III Snare Pad sending multiple triggers
Tried a different cable, but I'll try another one before busting it open. Thanks.
Sent: Tuesday, April 10, 2007 4:44 PM
Subject: [DTXpress] Re: DTX III Snare Pad sending multiple triggers
> look? Help!!
eliminate that.
Keith.
2007-04-11 by Jake Kurdsjuk
I understand. But my situation went from zero crosstalk to unusable literally overnight with no change to the kit settings or trauma to the pad.
Jake
Sent: Wednesday, April 11, 2007 7:08 AM
Subject: Re: [DTXpress] Re: DTX III Snare Pad sending multiple triggers
Hi there, I had this problem too, but the thing is there will allways be some crosstalk, and when you use different sounds then the rimshot and a snare it wil be more noticible. For exsample a big loud gong on the rim wil sometimes be triggered by a centerhit and thats disturbing so i dont use these combination on dualzone pad.
Good luck.
Gr Santana
10 Apr 2007 14:55:36 -0700, Jake Kurdsjuk <jake@churchplayer.com>:
> look? Help!!
eliminate that.
Keith.
Delay on input 8 and 9
2007-04-11 by Claude Mall
hello,
do anybody know why I get always a long delay on input 8 and 9 ? (Tom3
and crash2).
I use 8 for Bass Tom and 9 for Floor Tom.
I tried to tweek the delay but nothing realy helped.
If one of you had an idea how to improve those sounds.
Thnx
Claude
Re: Delay on input 8 and 9
2007-04-11 by Keith
--- In DTXpress@yahoogroups.com, Claude Mall <mall.claude@...> wrote:
> hello,
> and crash2).
Claude,
It is only a guess, but could it be caused by crosstalk?  Try playing
with the specific rejection, self rejection and general rejection
parameters in the trigger edit menu and see if you can affect it.
Keith.
Re: [DTXpress] Re: Delay on input 8 and 9
Keith,
the delay is not at the beginning of the sound, but at the end. It
sounds like loads of reverb or very long samples.
I tried to cut the hole thing and shorten the sounds, but it makes the
sounds " synthetic".
It helps a little bit when I shift the basic note, but not for all samples.
Maybe I'm not realy clear but it's hard to explain.
Claude
Keith a \ufffdcrit :
> --- In DTXpress@yahoogroups.com <mailto:DTXpress%40yahoogroups.com>,
> > hello,
> > and crash2).
> Claude,
> Keith.
2007-04-11 by Keith
> Keith,
samples.
> Claude
Claude,
It is difficult to describe sounds.  Some voices have a residual
"ringing".  Does it change if you change the voice?  Does the same
voice sound the same if you program it to a different pad? (i.e. it is
the specific to the voice, not the pad).
Keith.
