trying to use tp80s for 9/10 on dtxpress ii. need help!!
2007-01-04 by tinali1997
HI, happy new year.
i got a tp80s and trying to use it as two inputs onto 9/10. It only
give me pad9 sound nomatter how hard i hit the rim.
i tried 9/10 with tp65s, does not work either. but bother work on 2 as
snare fine.
any idea? thanks in advance. tom
Re: trying to use tp80s for 9/10 on dtxpress ii. need help!!
2007-01-04 by Keith
--- In DTXpress@yahoogroups.com, "tinali1997" <tinali1997@...> wrote:
> HI, happy new year.
> snare fine.
Tom,
Inputs 9/10 are intended for two separate pads, each with their own
piezo.  The dual zone pads use a single piezo and rim switch to get
two sounds, not two piezos.  By connecting a dual zone pad to 9/10 you
are connecting a piezo to one input and a switch to the other.  As you
have found out, it will not work.
If you want the two zone sounds from your TP80S, just about any other
input will do.  You will have to swap it with a single zone pad, e.g.
one of the toms and put the tom on 9/10.
Keith.
