"Magic Box" announcement
2005-05-24 by Keith
Hi all, Many of you will have seen discussions about the "Magic Box" which will allow two pads to use one input on the DTXpress, and also combine two piezos from a single pad into a single piezo and rim switch signal for use on the DTXpress (some non Yamaha dual zone pads use two piezos instead of a single piezo and a rim switch). I have designed a circuit which does a reasonably good job of doing this and a few people have tried it out. It is not 100% perfect and I am not sure it ever will be - it has to work within what the DTXpress expects from a pad with rim switch - but it is pretty good. However, I am not sure it will be viable as a commercial product and am not prepared to spend a lot of my own money to find out. As the original "Magic Box" was quite complex, I have come up with a simplified idea which should be within the abilities of anyone who wants to have a go. The components will only cost a few cents and the circuit is "passive" in that it does not use any external power (but has an "active" component). I have given it a quick try and it works and should be good for a typical use where you want to add a few pads for cow bells, extra cymbals etc. Bear in mind that when combining two pads into one input you can only get one sound at a time (although you can get both if one hit is slightly after the other) so you need to choose your combinations with some thought (ie don't combine the kick drum, snare or high-hat with anything). With a few extra components you could also combine three pads into one. I have posted a circuit to the files section. It is supplied without any warranty, but as it has now power, it is difficult to see how it can damage anything. I have not optimised the component values - I haven't time at the moment - so you may want to play around with them. I will try to answer any questions posted to the group as quickly as possible. If anyone wants the more complex circuit, please ask. It has opamps, comparators, inductors, power supply etc and would need a stripboard or something similar to build it on. The parts to build one would probably cost around $100 (I am not sure of USA component prices) and it would combine 8 channels into 4. Keith.
