TP80S pads and mono cables
2005-03-15 by Tom Allebrandi
Hi!
I prettied up my kit by neatly running the cables from the pads to the brain box, and then tying them down to the rack with cable ties.
Now, I'm in a situation where I need to use three of my TP80S pads and the brain box independent from the rest of the system. It would be a pain to undo all of the pretty cable routing in order to recover the cables for those three pads.
I have a supply of mono (Tip/Sleeve) instrument cables. I don't need the rim functions for what I am doing.
Can I safely use the mono instrument cables with the TP80S pads? I would think that the longer sleeve would place a short between the Ring and Sleeve positions in the "stereo"; Tip/Ring/Sleeve jacks in the pad and the brain box. As I recall, the brain box isn't bothered by this but I'm not so sure about the pads.
My brain box is a DTX V1 by the way\u03370;
Thanks for your help!
--- tom
tom@...
Re: TP80S pads and mono cables
2005-03-15 by Keith
and Sleeve
> positions in the "stereo" Tip/Ring/Sleeve jacks in the pad and the brain
so sure
> about the pads.
> My brain box is a DTX V1 by the way.
If you use a mono plug the DTX will think the rim switch is always
made.  The DTXpress ignores this, so I suspect the DTX does as well
(probably so you can use mono cables!).  For the pad, all you will be
doing is shorting out the rim switch - again it will do no harm that I
can think of.
Keith.
RE: [DTXpress] TP80S pads and mono cables
2005-03-17 by Tom Allebrandi
Keith -
Thanks for the confirmation. I tried it last night and everything seems
fine.
--- tom
> -----Original Message-----
> From: Keith [mailto:keith@...]
> Sent: Tuesday, March 15, 2005 01:59
> To: DTXpress@yahoogroups.com
> Subject: [DTXpress] TP80S pads and mono cables
> > Ring
> and Sleeve
> this but I'm
> > not
> so sure
> > about the pads.
> always made.  The DTXpress ignores this, so I suspect the DTX
> does as well (probably so you can use mono cables!).  For the
> pad, all you will be doing is shorting out the rim switch -
> again it will do no harm that I can think of.
> Keith.
> In low income neighborhoods, 84% do not own computers.
> At Network for Good, help bridge the Digital Divide!
> http://us.click.yahoo.com/c9hWNA/3MnJAA/n1hLAA/kkLolB/TM
> Community email addresses:
>   Post message: DTXpress@yahoogroups.com
>   Subscribe:    DTXpress-subscribe@yahoogroups.com
>   Unsubscribe:  DTXpress-unsubscribe@yahoogroups.com
>   List owner:   DTXpress-owner@yahoogroups.com
> Shortcut URL to this page:
>   http://groups.yahoo.com/group/DTXpress
> Alternate DTXpress site:
>   http://www.dtxpressions.com
