Trigger problem TP65S
2004-12-25 by bongokonzelmann
Well, I am sitting with a trigger problem with my DTXPIII. In certain situations the TP65S fails to trigger correctly. I didn“t notice this problem until I recently practiced with my band playing some old R&R stuff, that required to play quick quavers with the right hand and a stroke with the left hand every 4th quaver. When by coincidence it happens that both right and left stick hit the pad exactly the same time (you also can feel it by the kind of that special rebound) the effect is that the trigger signal is not louder (what you would expect) but sounds significantly softer. - Does anybody have come across that problem? Just for info: The snare is mounted to an own stand, no cross talk problems. All rejection parameters are reduced to lowest levels. Trigger curve "hard 2". The best Christmas wishes from Germany. Bongo.
