Idea's For Hooking Up Multiple Modules & Pads?
2004-11-18 by zapaxe
Just thinking of some creative routing and connection options...
This may be interesting to hear some idea's...I have a DTXpress I
set, with extra cymbal and drum pads. Also a DTXpress module and an
Alesis DM Pro module.
I was thinking about using all three drum modules for
selected/prefered drum and cymbal sounds, then routing the various
selected outputs into my mixer.
Other thoughts were to have two pads next to eachother as choices of
different Hi-Hat sounds. Maybe one controlled, and one just an
open/semi-open sound?
As for the snare I was thinking of doing the same as above or even
put a selector switch somewhere convenient to route the snare pad
from one module to another?
I know that I can cobine or layer samples together in one module,
but I was also thinking about splitting the snare's cord with a "Y"
and routing it to two modules to combine snare sounds.
Any otherbright ideas? :)
Steve
Re: Idea's For Hooking Up Multiple Modules & Pads?
2004-11-18 by emf
> I was wondering about compression and other effects. Are the samples
> already compressed sufficiently or do people route the whole thing
> through some sort of compression?
> J
Hi J,
By compression do you mean bringing the sounds below a certain
threshold? If so, the module has no ability to limit or compress; nor
would you need it unless your recording or other context required
that the signal be tamed to some extent. Just imagine if the module
had something comparable to a home theater's "midnight setting," to
keep the volume down while people were sleeping. You can't do
anything more considerate in that respect than playing through
headphones. Nor does the module have anything but bread and butter
reverb options. An outboard unit could certainly elaborate the sound
further, though unfortunately the DTXpress module doesn't allow the
components to be split beyond simple stereo for individual
processing. Sequencing would be an alternative.
If by compression you mean reducing the size of a file to fit a
certain application, into, say, an MP3, you'd have to do that by
recording to your PC and then using the appropriate program to
compress accordingly. Whatever Yamaha does to the samples to keep the
size down, if anything, the result at the module's output is pure,
uncompressed audio. And MIDI is, well, just MIDI.
Ed
Re: [DTXpress] Re: Idea's For Hooking Up Multiple Modules & Pads?
2004-11-18 by john@johnallsopp.co.uk
> Hi J,
Well, I'm definitely an amateur, but I have played with compression as
an effect and is certainly made things easier to listen to, and yes it
would be nice to compress the cymbals (that can make them last longer,
right?) but I accept it's all or nothing.
I've not gigged with the Yamaha but I was just thinking it might make
the sound 'smoother' somehow.
J
2004-11-18 by emf
as
it
longer,
make
Hey J,
If you've got a use for compression, more power to you. In the past,
when compression was all the rage, recordings acquired a signature
studio sound that I learned not to like. Compression can be used
judiciously, but the challenge with the DTXpress live would seem to
be not squeezing the life out of it. But I can see how the kit might
have a certain digital brashness that might bother people under
certain conditions. Keep us posted.
Ed
2004-11-19 by zapaxe
[Edited]
Hi, I'm thinking of some creative routing and connection options...
I have a DTXpress I pad set with extra cymbal and drum pads, dual &
single trigger. I'll likely get more pads... I also have three drum
modules, the DTXpress I, DTXpress III, and an Alesis DM Pro module.
Obviously with multiple modules I can run individual drum sounds out
for treatment of say the snare, for added FX's. And now I'll have
the capability to run a single drum sound into a recorded track.
With what I have I figure I can have about seven different cymbal
sounds. Maybe even alternate Hi-Hats and extra toms etc...
As for the snare I was thinking of even putting a "Y" adapter and
split the pads triggered signal to two modules to combine sounds,
similar to layering sounds in one module.
I thought about even using a selector switch somewhere convenient to
route, say the snare pad from one module to another independently,
and I could do this with other pads as well. This would be similar
to a patchbay, without having to plug and unplug cords. In fact, I
could make a Patchbay multi-selector switch box to route selected
pads that I may want to switch between the modules.
Not sure which module will control wich cymbal or drum pad at this
point. But I figure the DTXpress I module has the least impressive
cymbal samples...?
Any of your own thoughts or problems with my thought? This may be
interesting to hear some other idea's.
Steve
RE: [DTXpress] Re: Idea's For Hooking Up Multiple Modules & Pads?
2004-11-19 by rdamon@mckinney-usa.com
Steve,
You can run pads leads out to more than one module. You can also run pads
into multiple inputs on the same module, but the rejection settings have to
be played with. The only issue I ever ran across using multiple modules was
the crosstriggering  issue.
OGD
   _____
Sent: Friday, November 19, 2004 2:40 AM
To: DTXpress@yahoogroups.com
Subject: [DTXpress] Re: Idea's For Hooking Up Multiple Modules & Pads?
[Edited]
cymbal samples...?
Steve
The information transmitted herewith is sensitive information intended only
for use to the individual or entity to which it is addressed. If the reader
of this message is not the intended recipient, you are hereby notified that
any review, retransmission, dissemination, distribution, copying or other
use of, or taking of any action in reliance upon, this information is
strictly prohibited. If you have received this communication in error,
please contact the sender and delete the material from your computer.
______________________________________________________________________
This email has been scanned by the MessageLabs Email Security System.
For more information please visit http://www.messagelabs.com/email
2004-11-20 by zapaxe
Hi OGD,
This rejection you mention is only on one pad into multiple inputs
of the same module? Or is it for one pads into different modules as
well?
Truthfully I've never experienced rejection or crosstriggering, so
I'm not certain exactly what that is...?
I'll take a guess (with out RTFM)that rejection is the trigger not
triggering? and crosstriggering is unwanted triggering of other
voices/sounds?
I set up and mounted all my extra pads, and this weekend I plan to
hook up all three of my modules to my mixer. I supposes I be running
into more issues that I've never even heard of before :/
Steve
--- In DTXpress@yahoogroups.com, rdamon@m... wrote:
> Steve,
run pads
settings have to
modules was
> OGD
>    _____
> From: zapaxe [mailto:a_zapelectric@h...]
Pads?
> [Edited]
drum
out
to
> cymbal samples...?
> Steve
intended only
the reader
notified that
or other
is
error,
computer.
_
System.
_
2004-11-20 by oldguydrummer
Steve,
Briefly.....you adjust the rejection settings to prevent or minimize
cross-triggering. When you hit one pad and that pad sounds as well as
the pad next to it also triggers, even though you only hit one pad.
There are three rejection settings:
The first is the general rejection the pad peizo has to the rest of
the world, the rack, other thinks that make it vibrate in general.
The second is the rejection the pad has to itself. If the setting is
too low, one strike may cause the sound to play twice, instead of
once, because when you hit the pad hard, it doesn't instantly stop
vibrating, so if the continuing vibration is strong enough the module
will trigger the sound a second time, even though you only hit it
once.
The third rejection is the pad has to a second specific adjacent pad.
If when you hit the crash2 cymbal hard, and the vibration travels
down the mounting arm and down to Tom4 and cause Tom4 to trigger, you
will have to adjust the Tom4 (input 5) specific rejection setting to
the crash2 (input 11) to a higher number until the Tom4 no longer
triggers accidentally when you strike the crash2 pad.
When you use multiple modules the first two items can easily be
handled, but the third is difficult, but not impossible to handle.
You have to use up spare inputs on each module and use some Y-
splitter cables.
The way I handled it was dividing the rack up into three sections,
left rack pads went to module 1, middle rack pads went to module 2
and the right rack pads went to module 3.
If your pads aren't crammed together like mine, you shouldn't have a
problem.
OGD
--- In DTXpress@yahoogroups.com, "zapaxe" <a_zapelectric@h...> wrote:
> Hi OGD,
> well?
> voices/sounds?
running
> Steve
>> _
Thanks again OGD,
What you've said here has jogged my memory from reading the manual,
and beyond that with your experience of these isssues.
I understand what you're saying and can apply this as needed.
What I DON'T fully understand is when you say I MUST use up ALL
unused trigger inputs? Is this correct and why?
If I'm understanding this correctly, then I'm guessing that the 'Y'
cables are so that I can use say the crash cymbal and split them to
different modules?
Now I was thinking about the use of 'Y' cables anyway, along with
possible switchers from my pads cables to alternate a certain pad to
assign to one module to another, if I need to.
Thanks again, Steve
--- In DTXpress@yahoogroups.com, "oldguydrummer" <rdamon@m...> wrote:
> Steve,
minimize
as
of
is
module
> once.
pad.
you
to
> splitter cables.
a
> problem.
> OGD
wrote:
> > Hi OGD,
inputs
as
> > well?
so
not
> > voices/sounds?
to
> running
> > Steve
> >> _
Sorry for the confusion. What I was trying to say is that you have to
use up "a" spare on each module, not "all" spares. What you are
trying to do is have the ability to setup a "specific" rejection
between two interfering pads that are connected to two different
modules.
If you have a crash1 on module no. 1 on input no. 1 that is mounted
next to tom1 that is on module no. 2 on input no 1, and they are
causing crosstriggering, between these two pads, but everything else
is triggering fine, you have no way to use the specific rejection
function between two modules.
But if you run crash1 to both modules and use module no. 1/input no.
1 and module no.2/input no.7. You then setup the voice/volume as
needed for M1/I1 for the crash1 voice and you setup voice/volume on
M2/I7 as volume "0".
Now you can tell module 2 that you are having a rejection problem
between inputs no. 1 (Tom1) and input no. 7 (Muted-Crash1).
If you only have a "one-way" crosstriggering problem, then that all
you have to do.
I just wish they had added the ability to setup specific rejections
between more than one pad.
OGD
> > splitter cables.
Great OGD!:)
The confusion is on my end I'm sure:/ I've never dealt with these
issues before. "A" spare...got it! This is neccessary for programing
the rejection when needed.
Oh I see, run say a crash to both modules with the 'Y'. Hmmm..This
is going to be more work than I originally thought. I believe I
understand what you're saying now. I WILL have to refer back to this
post and the manual come hook-up time I'm sure.
Was going to hook up modules last night, got side tracked dusting my
studio...Maybe I should have has "spaceman" for my user name;)
Thanks once again, I may be back with this subject if I'm still
confused.
Steve
to
> modules.
mounted
else
no.
on
all
> you have to do.
rejections
> OGD
> > > splitter cables.
