OS X 10.4.4 problems !?!?
2006-01-31 by hodsonmonster
Hi there, IM using the Evo desktop with the latest OS. I also have a registered copy of the editor software. Everything worked fine untill I updated my OS to 10.4.4. I have the latest editor from your website. What happens is... I go to my Core Audio/Midi Setup in OS X and connect the IN and OUT of the Evolver into the IN 1 and OUT 1 of the MIDI device, which is an emagic MT4. I name my device 'Evolver' I go to the editor, open up the MIDI prefs, and it sees that I have chosen IN 1 and OUT 1 but it does not say 'evolver' next to the port in the MIDI setup just 'Port 1' . I make sure that the tick box is selected to use CoreAudio. I then try to send and receive programs and nothing happens. It plays fine in Logic, no problems. I have tried to use an earlier version of the editor software and the same thingg happens. I have made sure that trans and rec etc is set to 'all'. Therefore I think that the problem lies within core audio in 10.4.4! I have also tried the same midi device and setup on my laptop and the same thing happens! I have changed cables many times and still no joy... Im quite proficient at all this stuff, Im a technician in a studio and I have never had a problem with the Evo and its editor before. ANyone else having this problem? -Matt
