Casio CZ/ VZ/ FZ - Pro Series
Index last updated: 2026-04-28 22:42 UTC
CZ Voltage Selector to handle 220v and 110v
2015-08-31 by Jérôme
Hi all,
I just brought back in Canada a CZ-1 I bought in Europe and I trying to figure out what must be done to use it here with an adapted line chord without frying the board.
I guess it should be ready to be adjusted for different voltage specifications or else it wouldn't be very handy for touring musicians.
The owner manual, under power supply, is refering to: 100V, 120V, 220V, 240V AC. And then there is this warning: CHANGING THE VOLTAGE SELECTOR MAY REQUIRE THE USE OF A DIFFERENT LINE CORD OR ATTACHMENT PLUG, OR BOTH. TO REDUCE THE RISK OF FIRE OR ELECTRIC SHOCK, REFER SERVICING TO QUALIFIED SERVICE PERSONNEL GUIDELINES LAID DOWN BY FCC RULES FOR USE OF THE UNIT IN THE U.S.A. (not applicable to other areas).
Does anyone knows where is this voltage selector? Is it refering to an internal switch or it's a soldered part that must be changed?
Thanks a lot for your help!
Jérôme
Re: [CZsynth] CZ Voltage Selector to handle 220v and 110v
2015-08-31 by Daniel Forró
According to freely downloadable Service Manual (not the best quality)
this instrument has universal transformer with voltage selector in
primary circuit. Voltage selector is in the list of parts, so it must
be somewhere. That means no soldering or reconnecting cables is
necessary.
Because such selector is not described in Owner's Manual, it's inside
the machine, somewhere in PSU circuit near the transformer.
During changing the voltage pull AC cord from the mains. Good luck.
Anyway I don't think you can destroy it even when connected - Canada
has 120 V, Europe 220 V. It will just not work.
Daniel Forro
On Aug 31, 2015, at 7:12 PM, Jérôme jeromestpierre@...
[CZsynth] wrote:
> Hi all,
> musicians.
> areas).
> Jérôme
Hi Daniel,
I think I got an hardcopy of the service manual so I'll take a look at it. I don't really know how to read schematics but I should be able to figure out.
I'll have time to look at it tomorrow and I'll let you know how it went. If I can find it I'll take pictures of where it's located to post it somewhere because I couldn't find much about this online...
Thanks & have a nice one,
Jérôme
necessary.
Daniel Forro
On Aug 31, 2015, at 7:12 PM, Jérôme jeromestpierre@riseup.net
[CZsynth] wrote:
> Hi all,
> musicians.
> areas).
> Jérôme
2015-08-31 by Loscha
Regarding anything to do with Mains Power: ";I think I can work it out" is dangerous.
Get someone to look at it if you don't know what you're doing.
We want to see you around on the list next month!!!
On Mon, Aug 31, 2015 at 9:57 PM, Jérôme jeromestpierre@riseup.net [CZsynth] <CZsynth@yahoogroups.com> wrote:
Hi Daniel,
Jérôme
necessary.
Daniel Forro
[CZsynth] wrote:
> Hi all,
> musicians.
> areas).
> Jérôme
Hehe, don't worry, even though I don't know much in electronics I already managed to assemble a DIY synth on my own and I already fixed a few other synths too. I didn't bring my soldering kit but I don't think this will be very esoteric.
If the selector is not soldered and doesn't require to take everything apart just to access it I should manage to do it. In any case, if nothing bad happens, I'll let you know how it works!
Jérôme
"Loscha loscha@gmail.com [CZsynth]" <CZsynth@yahoogroups.com> a écrit :
Regarding anything to do with Mains Power: "I think I can work it out" is dangerous.
Hi Daniel,
Jérôme
necessary.
Daniel Forro
[CZsynth] wrote:
> Hi all,
> musicians.
> areas).
> Jérôme
Hi, Edward,
not so dangerous when we keep basic rules:
- do everything at once, step by step, without interruptions
(especially when somebody can touch the instrument, or switch it on
when you are not there or so - I've heard about such cases)
- check, check, check always and again
- keep away from the open machine all metal tools, or anything, which
could fell inside during the work, and be also aware not to fell
inside - keep order at your working place
- keep away curious children or pets
- work with the highest concentration and very carefully - even
experienced person can do a fatal mistake when opened machine is
switched on (I speak from my own experience after having good luck
more times in my life  to survive few high voltage shocks without
injury - that was good lesson)
- don't touch anything in mains circuit with naked fingers
- !!! disconnect the cord from mains !!!
- wait some time for discharging PSU caps
- if you have no experience with high voltage, never switch on the
opened machine
We want to hear about you tomorrow :-)
Daniel Forro
> out" is dangerous.
That's good you have some experience, but please be careful and don't work with instrument connected to the mains.
I suppose voltage selector is not switch type, more probably you have to pull out some upper part like connector with some pins, turn it according to some description about the voltage and reconnect it.
Let us know how it was...
Daniel Forro
Jérôme
2015-08-31 by 350ypvs@googlemail.com
Jerome, please post what you discover if you find a solution to your Europe to Canada CZ-1 voltage problem. I have emigrated to the USA and next year I will be shipping over my synth collection from the UK, which includes mains powered CZ-1, FZ-20M and VZ-1. I was looking at buying some 110v - 240 voltage converters, but if there's a simple switch inside the Casios that can make them run on 110v that would be much better.
Cheers!
Chas
On 31 August 2015 at 08:54, Daniel Forró danforcz@... [CZsynth] <CZsynth@yahoogroups.com> wrote:
Daniel Forro
Jérôme
I have moved from Europe to Japan 12 years ago with all my circus
(really lot of instruments and other gear) and had to solve similar
problem. My experience is:
- very few machines have PSU which accepts wide range of voltages and
switch automatically to any input voltage (example - Emu Systems
instruments, Apple computers...)
- only few instruments has universal transformer and voltage selector
- mainly older machines (for example some Yamaha, Roland, Korg,
Casio...)
- very few machines have voltage selector but quite unusable for my
case as it can switch only 100 or 120 Volts, or 200 or 240 (example -
Yamaha active speakers MS60S)
- few machine have universal transformer and inside are pins enabling
reconnecting to different voltage (example - Korg mixer 168RC)
- very few machines have universal transformer but it's necessary to
solder cables to different location (for example Roland JD800)
- most machines were manufactured for different world zones and can't
be switched to different voltage without changing transformer. I have
to use  step-up transformer changing Japanese 100 Volts to European
220 Volts. I have custom made big transformer  - 5 kW - for all
machines in my studio, one 2.5 kW which I use for concert gigs, and
few more smaller for different tasks and reserve.
Let's not forget when you change the voltage, it's necessary to change
also fuses! Try to find some information about this.
Daniel Forro
On Aug 31, 2015, at 11:16 PM, '350ypvs@...'
> Cheers!
> Chas
Daniel, thank you for the detailed and very useful information. It's interesting in that many modern power supplies in the form of "wall warts" - e.g. my mobile/ cell phone transformer, my digital camera transformer and the power supply for my laptop all work happily on 110v as they do on 240v, yet older electronic devices don't.
I was looking at buying a few of these for when I ship over my "circus" (good description - lol!) next year:
http://www.ebay.com/itm/271916970396?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Where did you get your custom made transformers made? My other option would be be to get something similar that could the be connected to a gang socket/ multi socket that I could then use to power all my UK instruments from.
Cheers!
Chas
On 31 August 2015 at 10:33, Daniel Forró danforcz@... [CZsynth] <CZsynth@yahoogroups.com> wrote:
I have moved from Europe to Japan 12 years ago with all my circus (really lot of instruments and other gear) and had to solve similar problem. My experience is:
- very few machines have PSU which accepts wide range of voltages and switch automatically to any input voltage (example - Emu Systems instruments, Apple computers...)
- only few instruments has universal transformer and voltage selector - mainly older machines (for example some Yamaha, Roland, Korg, Casio...)
- very few machines have voltage selector but quite unusable for my case as it can switch only 100 or 120 Volts, or 200 or 240 (example - Yamaha active speakers MS60S)
- few machine have universal transformer and inside are pins enabling reconnecting to different voltage (example - Korg mixer 168RC)
- very few machines have universal transformer but it's necessary to solder cables to different location (for example Roland JD800)
- most machines were manufactured for different world zones and can't be switched to different voltage without changing transformer. I have to use step-up transformer changing Japanese 100 Volts to European 220 Volts. I have custom made big transformer - 5 kW - for all machines in my studio, one 2.5 kW which I use for concert gigs, and few more smaller for different tasks and reserve.
Let's not forget when you change the voltage, it's necessary to change also fuses! Try to find some information about this.
Daniel Forro
On Aug 31, 2015, at 11:16 PM, '350ypvs@googlemail.com' 350ypvs@... [CZsynth] wrote:
Cheers!
Chas
2015-08-31 by John Leimseider
On the VZ1 and several other Casios, the voltage switch is just a screwdriver operated rotary switch on the bottom. On the VZ1, it's underneath on the treble side... A few seconds to change it...
Sent from my iPad
On Aug 31, 2015, at 8:46 AM, '350ypvs@...<mailto:350ypvs@...>' 350ypvs@...<mailto:350ypvs@...> [CZsynth] <CZsynth@yahoogroups.com<mailto:CZsynth@yahoogroups.com>> wrote:
Cheers!
Chas
On 31 August 2015 at 10:33, Daniel Forr? danforcz@yahoo.com<mailto:danforcz@...> [CZsynth] <CZsynth@yahoogroups.com<mailto:CZsynth@yahoogroups.com>> wrote:
Daniel Forro
On Aug 31, 2015, at 11:16 PM, '350ypvs@...<mailto:'350ypvs@...>' 350ypvs@...<mailto:350ypvs@...> [CZsynth] wrote:
Cheers!
Chas
Thanks so much for that info. John. When I return to the UK next year, I will check the back of my Casios to see which have voltages that can be changed with a simple turn of a screwdriver. Great to know!
On 31 August 2015 at 11:04, John Leimseider john.leimseider@... [CZsynth] <CZsynth@yahoogroups.com> wrote:
Sent from my iPad
On Aug 31, 2015, at 8:46 AM, '350ypvs@...' 350ypvs@... [CZsynth] <CZsynth@yahoogroups.com> wrote:
Cheers!
Chas
Daniel Forro
On Aug 31, 2015, at 11:16 PM, '350ypvs@...' 350ypvs@... [CZsynth] wrote:
Jerome, please post what you discover if you find a solution to your Europe to Canada CZ-1 voltage problem. I have emigrated to the USA and next year I will be shipping over my synth collection from the UK, which includes mains powered CZ-1, FZ-20M and VZ-1. I was looking at buying some 110v - 240 voltage converters, but if there';s a simple switch inside the Casios that can make them run on 110v that would be much better.
Cheers!
Chas
I forgot to mention external power supplies - that was easy: partly I
use original ones connected to the step-up transformer, partly I could
find their 100 Volt versions.
You are right that modern external power supplies accept wide range of
input voltages... But using them with musical instruments can cause
problem with hum or so - digital camera, battery charger, lap-top
computer or similar gear can use more simple adapters with not so good
filtering...
For making that huge and heavy transformer I have found a small
private firm in my old country. They did it pretty well, absolutely
professionally, and for good price. The only problem was to get this
almost 20 kg huge thing from Europe to Japan. Situation was
complicated by the fact I travelled to France for three day trip, and
then continue to Japan- that means checking-in at two airports.
Somehow I had good luck and could bring two big suitcases without
paying for overweight. But after checking in at the Nice airport I was
called by name few minutes before departure and security guys escorted
me to some room, I had to open the luggage, unpack and explain what it
should be, why I bring it with me and why it is so big :-) It looks
like it's not quite common souvenir from Europe trip. Fortunately it
was not confiscated, I was not arrested and could fly home with it.
I had to find a plastic box for it, make ventilation holes, add some
switch, fuse and connect cables... It serves me without any problems
about 10 years now.
The only problem in my studio is I have to be very careful when
disconnecting some instruments' cables - not to confuse them. Some are
for 100 Volts, some for 220. Of course there are different plugs, but
on some instruments I use only plug reduction, so I used tape to fix
it. Problem can start when cable is disconnected at the side of the
instrument - as these connectors are the same nowadays and can accept
cables with both Japanese or European plugs on the other end...
Nothing can happen when I do mistake and connect 220 V instrument to
100 Volts, but opposite way can be fatal case for the instrument. Of
course few years ago I did such mistake and my Kawai K5000W refused to
work after very short electroshock curing. Fortunately it is very well
made instrument, there's a lot of protection (Zener diodes or so) on
each board, main transformer survived, so I had just to replace most
of components in PSU - besides fuses voltage regulators, transistors,
and when doing it also resistors and capacitors and machine is OK.
Only FDD died, it is connected directly to PSU. It was quite easy to
find proper FDD as that one has slightly different pin assignment, but
after some experimenting I managed to find the right assignment.
Daniel Forro
On Aug 31, 2015, at 11:46 PM, '350ypvs@...'
> Cheers!
> Chas
I got it and my CZ-1 is now working on 120V. John was right, there was only a selector to turn underneath a part that had to be unscrewed.
I am glad I printed a binded copy of the service manual because it is not so clear. The dashed lines indicating each part are a little blurry. Anyhow, it was easy to identify the voltage selector on the 1-6 Power Supply schema but I had to look at the board for a good 15 minutes before to figure out.
Right beside the power connector, it's underneath the part labeled as ESE371 that is round with 5 wires coming out of it vertically. There is only 2 screws to pull out and underneath the switch is clearly indicating 100V, 120V, 220V and 240V.
This was well designed and it's very easy to do. I'll attached the 2 pictures I took that shows the part with the voltage selector.
Is there a FAQ section on Yahoo groups where I could post the illustrated instructions?
Cheers & have a nice one!
Jérôme
"'350ypvs@googlemail.com' 350ypvs@... [CZsynth]" <CZsynth@yahoogroups.com> a écrit :
>Sent from my iPad
>Cheers!
>Chas
>Daniel Forro
>Cheers!
>Chas
><!-- #ygrp-mkp { border: 1px solid #d8d8d8; font-family: Arial; margin: 10px 0; padding: 0 10px; } #ygrp-mkp hr { border: 1px solid #d8d8d8; } #ygrp-mkp #hd { color: #628c2a; font-size: 85%; font-weight: 700; line-height: 122%; margin: 10px 0; } #ygrp-mkp #ads { margin-bottom: 10px; } #ygrp-mkp .ad { padding: 0 0; } #ygrp-mkp .ad p { margin: 0; } #ygrp-mkp .ad a { color: #0000ff; text-decoration: none; } #ygrp-sponsor #ygrp-lc { font-family: Arial; } #ygrp-sponsor #ygrp-lc #hd { margin: 10px 0px; font-weight: 700; font-size: 78%; line-height: 122%; } #ygrp-sponsor #ygrp-lc .ad { margin-bottom: 10px; padding: 0 0; } #actions { font-family: Verdana; font-size: 11px; padding: 10px 0; } #activity { background-color: #e0ecee; float: left; font-family: Verdana; font-size: 10px; padding: 10px; } #activity span { font-weight: 700; } #activity span:first-child { text-transform: uppercase; } #activity span a { color: #5085b6; text-decoration: none; } #activity span span { color: #ff7900; } #activity span .underline { text-decoration: underline; } .attach { clear: both; display: table; font-family: Arial; font-size: 12px; padding: 10px 0; width: 400px; } .attach div a { text-decoration: none; } .attach img { border: none; padding-right: 5px; } .attach label { display: block; margin-bottom: 5px; } .attach label a { text-decoration: none; } blockquote { margin: 0 0 0 4px; } .bold { font-family: Arial; font-size: 13px; font-weight: 700; } .bold a { text-decoration: none; } dd.last p a { font-family: Verdana; font-weight: 700; } dd.last p span { margin-right: 10px; font-family: Verdana; font-weight: 700; } dd.last p span.yshortcuts { margin-right: 0; } div.attach-table div div a { text-decoration: none; } div.attach-table { width: 400px; } div.file-title a, div.file-title a:active, div.file-title a:hover, div.file-title a:visited { text-decoration: none; } div.photo-title a, div.photo-title a:active, div.photo-title a:hover, div.photo-title a:visited { text-decoration: none; } div#ygrp-mlmsg #ygrp-msg p a span.yshortcuts { font-family: Verdana; font-size: 10px; font-weight: normal; } .green { color: #628c2a; } .MsoNormal { margin: 0 0 0 0; } o { font-size: 0; } #photos div { float: left; width: 72px; } #photos div div { border: 1px solid #666666; height: 62px; overflow: hidden; width: 62px; } #photos div label { color: #666666; font-size: 10px; overflow: hidden; text-align: center; white-space: nowrap; width: 64px; } #reco-category { font-size: 77%; } #reco-desc { font-size: 77%; } .replbq { margin: 4px; } #ygrp-actbar div a:first-child { /* border-right: 0px solid #000;*/ margin-right: 2px; padding-right: 5px; } #ygrp-mlmsg { font-size: 13px; font-family: Arial, helvetica,clean, sans-serif; *font-size: small; *font: x-small; } #ygrp-mlmsg table { font-size: inherit; font: 100%; } #ygrp-mlmsg select, input, textarea { font: 99% Arial, Helvetica, clean, sans-serif; } #ygrp-mlmsg pre, code { font:115% monospace; *font-size:100%; } #ygrp-mlmsg * { line-height: 1.22em; } #ygrp-mlmsg #logo { padding-bottom: 10px; } #ygrp-msg p a { font-family: Verdana; } #ygrp-msg p#attach-count span { color: #1E66AE; font-weight: 700; } #ygrp-reco #reco-head { color: #ff7900; font-weight: 700; } #ygrp-reco { margin-bottom: 20px; padding: 0px; } #ygrp-sponsor #ov li a { font-size: 130%; text-decoration: none; } #ygrp-sponsor #ov li { font-size: 77%; list-style-type: square; padding: 6px 0; } #ygrp-sponsor #ov ul { margin: 0; padding: 0 0 0 8px; } #ygrp-text { font-family: Georgia; } #ygrp-text p { margin: 0 0 1em 0; } #ygrp-text tt { font-size: 120%; } #ygrp-vital ul li:last-child { border-right: none !important; } -->
A few years ago when I brought back my Korg DW-8000 I first tried to get it working with a cheap transformer I ordered from China and it didn't work. I thought it got damaged during transport but I actually had to buy a big chunky transformer in an electronic store to get it working.
I didn't understand why the cheap transformer failed to properly convert 110V to 220V but I guess I missed other important specifications...
Jérôme
"'350ypvs@googlemail.com' 350ypvs@gmail.com [CZsynth]" <CZsynth@yahoogroups.com> a écrit :
Cheers!
Chas
On 31 August 2015 at 10:33, Daniel Forró danforcz@yahoo.com [CZsynth] <CZsynth@yahoogroups.com> wrote:
Daniel Forro
On Aug 31, 2015, at 11:16 PM, '350ypvs@googlemail.com' 350ypvs@gmail.com [CZsynth] wrote:
Cheers!
Chas
That's excellent news Jerome, thanks for that information! If the CZ-1 has selectable voltage, then there's a good chance that my VZ-1 and FZ-20M will have too. Fingers crossed!
On 31 August 2015 at 15:17, Jérôme jeromestpierre@riseup.net [CZsynth] <CZsynth@yahoogroups.com> wrote:
Jérôme
Cheers!
Chas
Daniel Forro
Cheers!
Chas
2015-09-01 by Jérôme
Hi Daniel,
Thank you for this return of experience.
I didn't have any complicated issues before but for my 5 octaves keyboards from the mid-eighties that don't have external power supplies. I ended up running my DW-8000 on a big transformer like you that also provides more than enough watts to feed other units as well, but I didn't look to see if it has any voltage selector like the Casio yet. I'll enventually have to deal with an ESQ-1 as well and I hope it will be convenient.
Otherwise for my modern synths I just had to buy the corresponding PSU for 120V but this can be ridiculously expensive in music stores.
This is when I really appreciate manifacturers like DSI who not only provide PSU that supports from 100V to 240V but also provide the different adapters for America, UK and Europe.
Many thanks,
Jérôme
Daniel Forro
Cheers!
Chas
