Casio CZ/ VZ/ FZ - Pro Series
Index last updated: 2026-04-28 22:42 UTC
Casio CZ 101 Service manual
2010-04-08 by Baptiste
Does anyone have a CZ 101/ 1000 service manual which includes all the calibrations, and how to repair the CZ, not just the schematics?
Because I have a faulty CZ 101. The problem is when I push down more than one key, it starts to warble and sounds very distorted. I have been advised that it may be one of the op amps, but I would rather check the calibrations before replacing it.
Thanks!
Re: Casio CZ 101 Service manual
2010-06-08 by udon.juan
Hello Baptiste,
Did you ever come across anything? I have an old CZ-101 with similar problems, and I am looking to rehabilitate it.
Best, Udon
--- In CZsynth@yahoogroups.com, "Baptiste" <oscillate_wildly1@...> wrote:
> Hi,
> Thanks!
2010-07-04 by kasiofz
Hi
I'm searching too for the full service manual. Also I'm having the same problem here. i think that it has to do with the DAC offset voltage value. I measure it at about 2.5v DC. I also have checked a CZ-5000 service manual which states that the DAC offset voltage value must be around 300mV. The problem is that I can not figure out why I'm read this hi voltage value (2.5v). The VR2 trimmer  doesn't do anything. Please share any additional thoughts.
Regards
Bill
--- In CZsynth@yahoogroups.com, "udon.juan" <udon.juan@...> wrote:
> Hello Baptiste,
> Best, Udon
> --- In CZsynth@yahoogroups.com, "Baptiste" <oscillate_wildly1@> wrote:
> > Hi,
> > Thanks!
I want to add that if someone programs the internal sounds amp env maximum level at 55 value the distortion will stop when multiple keys are pressed down. Although the sound volume level will fall quite a lot.
Regards
--- In CZsynth@yahoogroups.com, "kasiofz" <kasiofz@...> wrote:
> Hi
> Regards
> Bill
> --- In CZsynth@yahoogroups.com, "udon.juan" <udon.juan@> wrote:
> > Hello Baptiste,
> > Best, Udon
> > > Hi,
> > > Thanks!
Re: [CZsynth] Re: Casio CZ 101 Service manual
2010-07-04 by Summa
Checked the relay the is grounding the output while the synth is
turned off?
On 4 Jul 2010 at 17:36, kasiofz wrote:
> Hi,
> quite a lot.
> Regards
> > Hi
> > Regards
> > Bill
> > > Hello Baptiste,
> > > Best, Udon
> wrote:
> > > > Hi,
> schematics?
> > > > Thanks!
CZ/VZ 		mailing list	: http://groups.yahoo.com/group/CZsynth
FMHeaven	mailing list	: http://groups.yahoo.com/group/fmheaven/
FS1R		mailing list	: http://groups.yahoo.com/group/fs1r/
Vokator		mailing list	: http://groups.yahoo.com/group/vokator
FM-Synthesis	mailing list         : http://groups.yahoo.com/group/fm-
synthesis/
http://www.summasounds.de/
I don't understand what "relay the" you are pointing out.
> turned off?
> > Hi,
> > quite a lot.
> > Regards
> > --- In CZsynth@yahoogroups.com, "kasiofz" <kasiofz@> wrote:
> > > Hi
> > > Regards
> > > Bill
> > > > Hello Baptiste,
> > > > Best, Udon
> > wrote:
> > > > > Hi,
> > schematics?
> > > > > Thanks!
> > Yahoo! Groups Links
> synthesis/
2010-07-04 by Summa
Sorry for the typo, the unusual heat is nagging on my
concentration...
relay = little electric controlled magnetic switch...
Looks like this...
http://www.conrad.de/medias/global/ce/5000_5999/5000/5030/5039/503916_
> Thanks
> > turned off?
> > > Hi,
> env
> multiple
> fall
> > > quite a lot.
> > > Regards
> > > > Hi
> the
> offset
> checked a
> voltage
> out
> doesn't
> > > > Regards
> > > > Bill
> wrote:
> > > > > Hello Baptiste,
> with
> > > > > Best, Udon
> > > wrote:
> > > > > > Hi,
> includes
> > > schematics?
> push
> amps,
> > > > > > Thanks!
> > > Yahoo! Groups Links
> > synthesis/
synthesis/
So you are referring on the relay of the M4152-MA2M board. I will check right now..
Thanks a lot
> concentration...
> Looks like this...
> > Thanks
> > > turned off?
> > > > Hi,
> > env
> > multiple
> > fall
> > > > quite a lot.
> > > > Regards
> > > > > Hi
> > the
> > offset
> > checked a
> > voltage
> > out
> > doesn't
> > > > > Regards
> > > > > Bill
> > wrote:
> > > > > > Hello Baptiste,
> > with
> > > > > > Best, Udon
> > > > wrote:
> > > > > > > Hi,
> > includes
> > > > schematics?
> > push
> > amps,
> > > > > > > Thanks!
> > > > Yahoo! Groups Links
> > > synthesis/
> > Yahoo! Groups Links
> synthesis/
There is a resistor (2.7kohm) between the relay normally closed terminal and the outputs ground. Although I see continuity between the relays common pin and one of the resistors terminals. I guess that its right.
Any suggestions ?
> Thanks a lot
> > concentration...
> > Looks like this...
> > > Thanks
> > > > turned off?
> > > > > Hi,
> > > env
> > > multiple
> > > fall
> > > > > quite a lot.
> > > > > Regards
> > > > > > Hi
> > > the
> > > offset
> > > checked a
> > > voltage
> > > out
> > > doesn't
> > > > > > Regards
> > > > > > Bill
> > > wrote:
> > > > > > > Hello Baptiste,
> > > with
> > > > > > > Best, Udon
> > > > > wrote:
> > > > > > > > Hi,
> > > includes
> > > > > schematics?
> > > push
> > > amps,
> > > > > > > > Thanks!
> > > > > Yahoo! Groups Links
> > > > synthesis/
> > > Yahoo! Groups Links
> > synthesis/
