AVR-Chat
Question about using PWM to an RC
2006-01-07 by James Washer
Below is my (limited) understanding of PWM DAC.. I'm just looking for comments regarding (any) mistakes in my understanding.
Assume we are driving the DAC with an AVR and the DAC's load has infinite impedance (i.e. opamp voltage follower or some such circuit)
When using PWM to "charge" the capacitor in an RC to do DAC, one generally chooses a time constant much greater than the PWM frequency.  If I'm thinking about this correctly, the larger the RC, the lower the "ripple".
However, the larger the time constant, the lower the response of the DAC.  i.e. since it takes ~5RC seconds to hit  ~99% charge on the cap, the larger the RC, the longer it will take for the DAC to settle on a given voltage.
Assuming these two points are  true, then the tradeoff becomes ripple vs responsiveness. Is this correct?
Finally, I would assume one needs to worry about the "ratio" of R to C.  If one chooses a LOW resistance and a large capacitance, we might still have a reasonable RC compared to the PWM frequency, however, we'll also have large currents on the AVR pin. Is this correct?
Further is one chooses a high resistance with small capacitance, the circuit becomes more sensitive to it's output load.
Thanks for reading this far.. Please correct any mistakes... I'm a beginner at all of this.
Re: [AVR-Chat] Question about using PWM to an RC
2006-01-07 by Tom Becker
One would never know; you have a good grasp.
PWM DACs are based on averaging pulses to a corresponding equivilent
voltage or current.  The average is usually generated by using an RC, a
simple filter that reduces high-frequency components, and it's values
depend on your need.
If you are generating a stable DC offset voltage, for example, you need
a long time constant - perhaps limited by the load resistance.  If
you're generating an AC signal, the filter needs to be faster - perhaps
limited by the source impedance.  In both cases the instantaneous error
is caused by the filter characteristics and, in both cases, an opamp can
help.
Tom
2006-01-08 by Thomas Keller
  I am confused.  Why wouldyou drive a DAC with PWM?  If you're using a
DAC, just output the digital value to the DSAC, either in parallel or
serial format (depending onthe DAC).  Or, use PWM to accomplish Digital
to Aanlog conversion.  Why would you combine the techniques?  Using PWM
makes the DAC superfluous and redundant.
tom
P.S.  someone do correct me if I am mistaken in this
>>tom
  sheesh*here I am replying to myself.  In reading the many responses to
this message, I realize that I was, indeed, confused about what was
being asked.  *heh*  Open Mouth,
tom Insert Foot
2006-01-08 by James Washer
No problem.. I likely stated my questions poorly... i.e... I'm using PWM and a L.P filter to creat a DAC
On Sat, 07 Jan 2006 21:39:58 -0600
> >>tom
> tom Insert Foot
