AVR-Chat
Re: [AVR-Chat] question about serial port bit banging
2005-12-27 by Jim Wagner
Jim -
There is an Atmel apnote on bit-banged serial. It should be
on the Atmel website AND on the AVRFreaks.net site. It
should save you a lot of hassle! If you look at the
waveforms for a standard serial UART, you will see what the
idle levels are at the I/O pin.
Cheers
Jim
On Tue, 27 Dec 2005 11:10:06 -0800
 James Washer <washer@trlp.com> wrote:
> I need to implement a bit-bang serial port. It's my
> understanding the RS232 "idles" high, which would mean
> the logic level out of a max232 would be low. The start
> bit would then be logic high to the AVR.. Is this
> correct?
> thanks
>  - jim
> Get Bzzzy! (real tools to help you find a job). Welcome
> to the Sweet Life.
> http://us.click.yahoo.com/KIlPFB/vlQLAA/TtwFAA/dN_tlB/TM
The Think Different Store
http://www.thinkdifferentstore.com/
For All Your Mac Gear
2005-12-27 by James Washer
I need to implement a bit-bang serial port. It's my understanding the RS232 "idles" high, which would mean the logic level out of a max232 would be low. The start bit would then be logic high to the AVR.. Is this correct?
thanks
 - jim
2005-12-27 by Dennis Clark
This is correct.
DLC
> thanks
>  - jim
Dennis Clark    TTT Enterprises
Re: question about serial port bit banging
2005-12-27 by Ingvar Esk
No, if I understand you correct. The word "high" is missleading.
Serial comm idles at a logical "true" or "1" level. On the RS232 side
this is represented with a -15 to -3V signal. On the TTL side of the
MAX chip it is represented by a 5V signal. The reverse, a logical
false or "0", is represented by a +3-+15V signal and a 0V signal
respectivily.
Ingvar
2005-12-27 by Don Kinzer
> Is this correct?
Yes.
As you may know, the trick to bit banging a serial input is to arrange
to sample the input line consistently somewhere near the middle of the
bit window.  Generally, this means that you need to sample the input
line at some multiple of the bit frequency (probably 4x is the lowest
practical multiple, 8x or higher is even better if you can afford the
overhead) and then arrange to sample the input line at multiples of
the bit time after a start bit has been detected.  This process is
complicated by the fact that the transmitter's clock can have
virtually any phase relationship to the receiver's clock so you have
to design your software to accommodate the worst-case clock skew.
Moreover, the transmitter's clock and the receiver's clock can vary
from the ideal frequency in opposite directions and the resultant
error is cumulative over the 9 to 11 bits of the character being
received.
Compared to reception, bit bang transmission is a cinch.
I implemented a 4-channel bit bang full duplex UART in assembly
language for the ZX microcontrollers; they are based on a mega32
running at 14.7456MHz.
Don
ZBasic Microcontrollers
http://www.zbasic.net
Re: [AVR-Chat] Re: question about serial port bit banging
2005-12-28 by James Washer
Yes, this is what I found to be true in (my limited) testing.. This is the opposite of what I believed to be true ( and attempted to write ) when I posted my question early.
On Tue, 27 Dec 2005 22:21:50 -0000
> respectivily.
> Ingvar
2005-12-28 by dlc
Indeed,
   I generally sample the bit stream at the fastest rate I can, between
16 and 60X the clock rate, then arrange subsequent checks to be centered
in the rest of the bits.  I've gotten a 4MHz 12C508A to run reliably on
its internal RC oscillator at 9600 bps and a Tiny12 at 1MHz at 9600 bps.
  The 12C508 was totally on a timed FSM, the Tiny12 had the advantage of
having an IRQ that I could use on a timer.  All in assembly of course,
you probably couldn't get a receiver to work well using a high level
language.
fun stuff,
DLC
>>Is this correct?
> Yes.
> received.
> Don
www.techtoystoday.com
2005-12-28 by Zack Widup
Microchip has an application note on serial comm that even gives routines
for the timing and formulas to calculate the values used in the timers.  I
forget which one it is but I have it around somewhere.  I've used it
successfully with PIC16C54, 16F84 and 16F876.
The only problem is that the timing uses simple one-loop counters.  For
higher frequency crystals you would need to go to nested loop counters or
much faster baud rates.  9600 baud is difficult to implement with an AVR
running at 16 MHz.  Not impossible but more complicated.
Zack
On Wed, 28 Dec 2005, dlc wrote:
> Indeed,
> language.
> fun stuff,
> DLC
2005-12-28 by Gary Dion
Hi Jim.
Should you be using the AVR GCC compiler, you are welcome to some
code I wrote to implement a full-duplex software UART.  The function
is set up to be called at 4x the baud rate you want.  I run it at
4800 baud (ie. it's called at 19.2kHz) for a GPS receiver, but 9600
works just fine too (when called at 38.4kHz).  This is on an ATmega8
running at 14.7456mHz and I haven't had any problems.
But to answer your question:
In TTL (I/O pin), idle is high, and the start bit is low.
In RS-232, idle is low, and the start bit is high.
You can find this and more on page 134 of the ATmega8 manual.
-Gary
> thanks
>  - jim
2005-12-28 by Don Kinzer
--- In AVR-Chat@yahoogroups.com, Zack Widup <w9sz@p...> wrote:
> 9600 baud is difficult to implement with an AVR running at 16 MHz.
My 4-channel implementation can run at 19200 baud reliably but only if
just one channel is open.  For 2 to 4 channels, the maximum baud is
limited to 9600.  Of course, at the higher rates there's not much time
left to do very much other processing so a lower maximum rate is
better.
Don
2005-12-28 by poitsplace
Did you use the timer interrupt for that?  Seems like it would have
less overhead than a delay loop (for reasons besides the fact that you
had the MCU do nothing)
if
time
> better.
> Don
I've got my avr-gcc mega8 full-duplex SW uart working.. just need to optimize it a bit now.. Thanks's for the kind offer of your code. Once I get mine where I want it, I'll take a look at yours. I'm fairly new to microcontrollers, so I like to take a stab at everything myself, before I borrow code.
thanks again
 - jim
On Wed, 28 Dec 2005 16:44:41 -0000
"Gary Dion" <gdion@engineer.com> wrote:
> Hi Jim.
> -Gary
> > thanks
> >  - jim
> have less overhead than a delay loop.
Yes.  In this particular system the serial transmission and reception
occurs "in the background" while other work is being done.  Each
serial channel has its own transmit and receive queues serving as the
source and sink for the data.
Don
