AVR-Chat
Help, Compiler ignores some part of the function!
2005-11-11 by karademu
Hello All,
Using WinAVR-20050214, I try to compile the following function, but
the section between [BOOKMARK1] and [BOOKMARK2] does not get compiled
without any error indication. İ checked the routine in the .lst file,
this section is not compiled to assembly. The rest is there. Any idea,
what is wrong?
Thanks.
Murat Karadeniz
http://www.onlinefavbar.com/mukas
Note: target CPU is ATMEGA16 and avr-size after compilation gives:
   text    data     bss     dec     hex filename
  11065      78     585   11728    2dd0 main.elf
void ProcessPID_Vertical()
	#define encoder Motor1_Counter
	#define PWMchannel 1
	#define IntegralActivationLimit 12
	static long integral_error = 0;
	static long prev_error = 0;
	static long prev_prev_error = 0;
	long error;
	int controller;
#ifdef USE_INTERNAL_ENCODER_CONSTS 				//
destinationVertical given in angles at the final moving axis
	ErrorVertical = error = ( DestinationVertical / enc1_constant )
- encoder; #endif
#ifndef USE_INTERNAL_ENCODER_CONSTS				//
destinationVertical given in encoder ticks at the motor encoder for
the same final motion
	ErrorVertical = error = DestinationVertical - encoder;
#endif
	if (error  == 0)
		controller = 0;
	else
		integral_error += i1*error*10;
		if (integral_error > INTEGRAL_LIMIT_V)  integral_error =
INTEGRAL_LIMIT_V;
		if (integral_error < -INTEGRAL_LIMIT_V) integral_error = -
INTEGRAL_LIMIT_V;
[BOOKMARK1]
		if ((d1*(error -prev_prev_error)/2 <
IntegralActivationLimit) && (d1*(error -prev_error)/2 > -
IntegralActivationLimit))
			if ((error < PTERM_AMPLIFICATION_CLOSURE_V) &&
(error > -PTERM_AMPLIFICATION_CLOSURE_V))
				controller = (int) (
p1*error*PTERM_AMPLIFICATION_MAGNITUDE_V + integral_error/10 +
d1*(error -prev_prev_error)/2);
			else
				controller = (int) ( p1*error +
integral_error/10 + d1*(error -prev_prev_error)/2);
		else
p1*error*PTERM_AMPLIFICATION_MAGNITUDE_V + d1*(error -prev_prev_error)
/2);
			else
				controller = (int) ( p1*error + d1*(error -
[BOOKMARK2]
		if ( controller > 0 )
			SetDirection2(LEFT);
		else
			SetDirection2(RIGHT);
		if ( controller > SPEED_LIMIT_V ) controller =
SPEED_LIMIT_V;
		else if ( controller < -SPEED_LIMIT_V ) controller = -
SPEED_LIMIT_V;
	prev_prev_error = prev_error;
	prev_error = error;
	//WritePWM(PWMchannel, abs(controller));
