AVR-Chat
Re: [AVR-Chat] Re: Intercom using single LED
2005-10-10 by stevech@san.rr.com
this seems to wire an (infrared) LED to an output bit. And a photosensitive diode to the input port of a different micro. Well, this is OK if (a) the receiver diode is never near light/sunlight and (b) the intended range is very short. A practical system would not use a simple diode for receiving; it would use a $3.00 IR receiver module and the data would be modulated on a carrier like 38KHz. This is how TV remotes work. The receiver module has a bandpass filter yielding a reasonable signal-to-noise. The data coding varies but the "RC5" pseudo-standard is popular.
Date: Monday, October 10, 2005 10:39 am
Subject: Re: [AVR-Chat] Re: Intercom using single LED
> On Mon, 2005-10-10 at 12:28 +1000, Peter Jakacki wrote:
> > I call it my 20 cent wireless coms.
> > Basic circuit connections:-
> > GND ~~ [LED- LED+] ~~ 10K ~~ BASE
> > LED+] ~~ 100R ~~ OUTPUT PORT ( or use a PNP for
> more
> > drive or if using a UART )
> > VDD ~~ PULL-UP ~~ COLLECTOR ~~ INPUT PORT
> > GND ~~ EMITTER
> Uh...call me dense, but this means nothing to me. Could you
> explainyour notation, please?
> Tom
> ------------------------ Yahoo! Groups Sponsor --------------------
> Get Bzzzy! (real tools to help you find a job). Welcome to the
> Sweet Life.
> http://us.click.yahoo.com/A77XvD/vlQLAA/TtwFAA/dN_tlB/TM
> Yahoo! Groups Links > <
2005-10-10 by Peter Jakacki
I think you guys miss the point of single LED wireless coms. It is only
intended for a very short distance such as when an operator stands in
front of the instrument etc. Sure, I've used the IR receiver's before
but that is another kettle of fish altogether and not really suitable
for UART coms, especially at higher baud rates. BTW, the ambient light
conditions have to be fairly bright before this circuit may need some
simple shielding such as recessing the LED.
The circuit notation is obvious if you have ever wired a circuit up
before, otherwise you may find it a bit terse. The "~~ 10K ~~" means a
10K resistor with the connections on either end, BASE means connection
to the BASE of the transistor etc etc. What else would BASE mean? It is
possible to use ASCII art to draw the circuit, but I always find that
laborious, a bit like illuminating manuscripts.
Anyway, you guys can be academic about it all and compare apples and
oranges all day long if you like. I'll keep on doing what an engineer
does best .... being practical.
*Peter*
>----- Original Message -----
>From: Thomas Keller <tkeller1@neb.rr.com>
> > more
> > > GND ~~ EMITTER
> > Tom
2005-10-11 by Thomas Keller
> is possible to use ASCII art to draw the circuit, but I always find
> that laborious, a bit like illuminating manuscripts.
   Well, with that information, I can now make sense of the description,
though I must say in over 35 years of doing electronics as both a
hobyist and a professional, I have never seen a circuit described in
this way.
   Also, what does 100R indicate?
   Since you didn't specify the environment of the application, their
comments were completely appropriate.   In most REAL WORLD applications,
the system you are describing would be, at best, unreliable.  Engineers,
being practical, attempt to engineer in enough head room to keep the
system woirking under adverse conditions, actually...*THAT* is what
"engineers" do.
Tom
2005-10-11 by Peter Gargano
Tell me that's a trick question!
In case it's not, here's the first thing Google picked up!
   http://www.lalena.com/audio/electronics/color/
35 years huh?
Peter
RE: [AVR-Chat] Re: Intercom using single LED
2005-10-11 by stevech
In the US, history says a resistor less than 1000 ohms is written as just a
number. No "R". I suppose you can find examples in the US such as 1R5 for
1.5 ohms; not sure.
Shall we move on to British "earth" versus US "ground"?
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf
Of Peter Gargano
Sent: Monday, October 10, 2005 7:36 PM
To: AVR-Chat@yahoogroups.com
35 years huh?
Peter
Yahoo! Groups Links
2005-10-11 by John Samperi
I believe 100R or whatever is an international standard
and has been so for a long time (20 years??)
Regards
John Samperi
                         Ampertronics Pty. Ltd.
   11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
          Tel. (02) 9674-6495       Fax (02) 9674-8745
                Email: samperi@ampertronics.com.au
                  Website  http://www.ampertronics.com.au
* Electronic Design   * Custom Products   * Contract Assembly
>  35 years, huh?
  I've always been confrontational, but you really take the cake, Peter!
  "R" is the color red, so what is the 100 supposed to indicate? I've
never before seen color used in a circuit description. There is no
common electrical unit I am aware of that is designated by an "R" in
that manner.  Is this more of your view of "being practical?"
  I apologize to the members of the list, but this guy's attitude is
beginning to really rankle on me. I did manage to control myself to the
extent of watching my language, but it wasnt easy!
Tom
   Ok that is possible, and makes sense to me.   I spent the better part
of the past 20 years NOT being ionvolved directly in electronics, so I
may have missed something.   Back in "the day," resistance values on
schematics were indicated by either just a number (e.g., 10,000) or by a
number followed by a lower case omega.  On rare occasions, some
drafts-people would indicate with the number and the word "ohms."
   I would like to note that I was not challanging Peter on that issue,
I honestly didn't understant the notation, just as I didn't understand
his schematic notation.
Tom
2005-10-11 by Kathy Quinlan
> Tom
This is not so much a "British" thing as a "German" thing, with the Din
and ISO standards for drafting, all decimal points are replaced by a
letter indicating the decimal point eg a 1.2K resistor is 1K2, bellow 1K
we use an R as it is easier to draft than an omega.
I agree that it different, but it is just what you are used to.
Kat.
K.A.Q. Electronics	Website: www.kaqelectronics.dyndns.org
IM: Yahoo: PinkyDwaggy  MSN: katinka@kaqelectronics.dyndns.org
For Everything Electronics     Phone: 0419 923 731
Checked by AVG Anti-Virus.
Version: 7.0.344 / Virus Database: 267.11.14/128 - Release Date: 10/10/2005
2005-10-11 by Dave Hylands
The link that Peter posted
<http://www.lalena.com/audio/electronics/color/> explains the use of R
quite well. The suffix M means x 10 to the power 6. The suffix K means
x 10 to the power 3, and the suffix R means x 10 to the power zero.
So, 100K means 100,000 ohms. 100R means 100 ohms.
The R is often used in place of a decimal point, since the decimal
point is so hard to see, especially on small surface mount devices.
6R8 means 6.8 ohms.
With surface mount devices (at least the ones I've seen), they use the
R and not the K or M. So 10K would be written as 103.
Dave Hylands
Vancouver, BC, Canada
http://www.DaveHylands.com/
2005-10-11 by Zack Widup
I have seen this notation used on quite a few schematics lately, most
coming from Germany or Japan.  I figured it meant just what you noted,
Kat.  In the same drawings I've seen notations like 2R7 and 0R27, etc.
Zack
> Regards,
> Kat.
> I've never before seen color used in a circuit description. There is
> no common electrical unit I am aware of that is designated by an "R"
> in that manner.  Is this more of your view of "being practical?"
  Ah!   My error.   When I saw the color code chart on that site, I
looked no further, as I was considerably irritated/  Maybe I need to
calm down a bit, eh?  *smile*
   This notation is decidedly new to me. I have never seen it or heard
of it before.  I guess being out of the game for 20 years can really
foul you up.
Tom
2005-10-11 by Peter Jakacki
Hi Tom,
Don't get us Peters mixed up now! (look at the column that says "Sender") :)
I could of attached a nice little schematic but that would of been
filtered out and so we are left
with either a link to a webpage or inline ascii schematics. I'm only
trying to be helpful but I really didn't want to spend any more time on
supplying the details than I did. Usually I attempt some ascii
schematics and this time it seemed ok just to supply it in a totally
non-standard pseudo-netlist form.
Also, the circuit works well for it's intended use and allows firmware
uploads/data downloads etc without having to have an external connector,
which sometimes is not possible or desirable. Sometimes this circuit
just sits on a PCB internal to the equipment, accessible only by
technicians when there is some diagnostics or firmware uploads to do.
Finally, there is nothing safety-critical about the use of this coms
circuit. Nobody is trying to reliably control any lump of equipment, big
or small, with the lousy stream of photons emanating from this circuit.
Practical does not mean all-encompassing, if a clothes peg keeps your
washing on the line then it is practical for that purpose.
:) keep smiling
*Peter*
>Tom
2005-10-11 by erikc
>>Tom
Also, omega is not found in most character sets.  I for one would be
happy to at least see lower case mu, pi, and the uppercase omega in any
of the standard character sets since I use those symbols all the time in
my (technical) writing.
Actually, I find it such a sensible form of notation that I now use it
myself (I'm a Yank)  ;-)
An OT question of my own:  On European drawings, they use a certain very
legible font-face when labelling thier drawings.  I'm wondering if that
font isn't also a DIN/ISO specification as well, and if so, what is it.
> Regards,
> Kat.
erikc
2005-10-12 by Russell Shaw
>>>Tom
Switch to a unicode locale and configure your keyboard to put the greek
symbols into the second group (using xkb in linux).
