AVR-Chat
AT90CAN128
AT90CAN128
2005-10-05 by David Collier
If I run this chip off a 32KHz XTAL.. does it multiply up internally,
or does it actually RUN at 32KHz???
David
Re: [AVR-Chat] AT90CAN128
2005-10-06 by Thomas Keller
  AVR microprocessors do not contain PLLs in their clock circuitry.
They run at whatever frequency the clock is running at, unless you
choose to divide that frequency in those chips which support clock
division (which I believe includes the entire line of AVR chips).
Tom
2005-10-06 by Hugo Oliveira
Hi Tom,
AT90PWM3, does have a PLL, It is used for the CPU clock and for the
PSC (PWM controllers).
Regards
Hugo
> Tom
RE: [AVR-Chat] AT90CAN128
2005-10-07 by Larry Barello
Not true.  Look at the tiny26 oscillator circuit.  They don't use a 32khz
clock for the PLL source, however.
Larry Barello
www.barello.net
| -----Original Message-----
| From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf
| Of Thomas Keller
| Sent: Thursday, October 06, 2005 8:44 AM
| To: AVR-Chat@yahoogroups.com
| Subject: Re: [AVR-Chat] AT90CAN128
| Tom
| Yahoo! Groups Links
2005-10-07 by Thomas Keller
On Thu, 2005-10-06 at 17:11 -0700, Larry Barello wrote:
   One of these days I am going to learn not to shoot from the hip, as
it were.   *blush*    I sit corrected (if you think I check my email
while standing, think again!)
Tom
> 32khz
> Larry Barello
> www.barello.net
> Behalf
> | Of Thomas Keller
> internally,
> | Tom
> | Yahoo! Groups Links
> ______________________________________________________________________
> YAHOO! GROUPS LINKS
>      1.  Visit your group "AVR-Chat" on the web.
>      2.  To unsubscribe from this group, send an email to:
>          AVR-Chat-unsubscribe@yahoogroups.com
>      3.  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>         Service.
*sigh*
  OK.    I suppose now I am going to have to go and read every data
sheet on Atmel's website, so I don't stick my foot in my mount again
like this.
  Query:  are these PLLs used with external crystal or clock sources to
multiply the clock frequency, or are they there for other purposes?
Whyt use an expensive PLL circuits for chips that don't run any faster
than 20 Mhz (except for that one, sweet 48 Mhz chip they just brought
out)?  It's not like a 4 or 5 Mhz cyrstal costs any less than a 20 Mhz
crystal, so why would they bother?
Tom.
On Thu, 2005-10-06 at 20:07 -0300, Hugo Oliveira wrote:
> Hi Tom,
> Regards
> Hugo
> internally,
> > Tom
> > Yahoo! Groups Links
> YAHOO! GROUPS LINKS
>         Service.
2005-10-21 by David Collier
internally,
So running the CPU on a watch XTAL gives you a pretty slow computer - I
assume you can run on the internal osc, and use the 32KHz as a timing
reference to trim it then?
David
2005-10-22 by Thomas Keller
> internally, or does it actually RUN at 32KHz???
> I assume you can run on the internal osc, and use the 32KHz as a
> timing reference to trim it then?
   If I understand what you are asking, I believe the answer is no.
Depending on WHICH AVR processor you are using, the internalk oscillator
is either fixed, or can be trimmed by writing to the OSCCAL register.
So far as I understand it, the 32 Khz oscillator is used strictly for
the watchdog timer, and to start up the processor from a deep sleep
state (someone who knows more correct me if I am wrong, please?).
Tom
