AVR-Chat
bulk programming
bulk programming
2005-10-02 by David Collier
I'm locking at building a design which would use an ATtiny25, and a
couple of transistors on a tiny PCB.
The chip is really cheap, but I don't want to spend double that on
getting it programmed and tested.
Naturally these would be built in a panel, maybe even 256-off on a
single PCB.
If I want to I can score one side of the PCB, and allow connections
across and between the units while the panel is still whole.
It may be a real help if I can test all 256 units on the big panel
before breaking them up for installation.
What are my options for programming up these 256 chips?
Can I buy them preprogrammed with either my own code, or a bootstrap
loader?
Can I program many in parallel using a common sequence?
Is it possible for an ATtiny to load it's own code and program itself?
( I might happily go up to an ATtiny45 if by doing so I could automate
the programming )
I had a mad idea of trying to organise them all into a bucket-brigade,
so each one programmed the one on it's left :-)
Re: [AVR-Chat] bulk programming
2005-10-03 by Jim Wagner
SPI programming of lots of chips on a single board would be
a challenge because, somehow, you have select one out of
many. The reset line functions as a sort of chip-select and
implementing that, with some sort of logic on your panel
seems like a looser.
The company I used to work for had 2313s pre-programmed at
Arrow, one of our Atmel distributors. That, however, was in
a DIP package. There has been some debate on the AVRFreaks
list about the wisdom of trying to pre-program SMT parts
prior to solder-down with no definitive conclusion.
If I were doing it (as I may be soon), depending on the
volume, I would build the boards to drop very easily into a
programming fixture such that its not much more than a
button-push to program.
Jim
On Sun, 2 Oct 2005 14:51 +0100 (BST)
> ATtiny25, and a
> double that on
> 256-off on a
> single PCB.
> connections
> whole.
> big panel
> a bootstrap
> loader?
> program itself?
> could automate
> the programming )
> bucket-brigade,
> Fair play? Video games influencing politics. Click and
> talk back!
> http://us.click.yahoo.com/T8sf5C/tzNLAA/TtwFAA/dN_tlB/TM
The Think Different Store
http://www.thinkdifferentstore.com/
For All Your Mac Gear
