AVR-Chat
generating external interrup in SW
2005-09-30 by Aaron
On a mega48, I am trying to generate a external interrupt in the
software by writing:
    sbi EIFR, INTF0     ; simulate a step in test mode by setting INT0
flag (step input)
But this doesn't seem to work  -- neither in the simulator nor on real
hardware.
I am 99% sure INT0 is set up properly because the interrupt vector
executes if a falling edge is applied to the pin.
Is my method of generating an external interrupt in software valid, or
am I missing something?
Aaron
Re: [AVR-Chat] generating external interrup in SW
2005-09-30 by David Kelly
> flag (step input)
> hardware.
On the AVR one *writes* a 1 to the flag register to *clear* the flag.
There is no way to set the flag without tickling the external INT0 pin.
IIRC you can't write to the INT0 port pin to trigger the IRQ because
the act of enabling the IRQ disables it as an output.
Only way I can think to do what you ask is to wire another output
port pin to your INT0 input.
David Kelly N4HHE, dkelly@HiWAAY.net
Whom computers would destroy, they must first drive mad.
2005-09-30 by Mark Jordan
	He could "rcall" the INT0 routine...
	Mark Jordan
