> Hi all,
> I found an example using the Nordic nRF2402 however is there some
other
> company that makes the same tranceiver in a diffrent package?
> Thanks in advance,
> Javier
Hi Javier,
The 2402 is only a transmitter, the 2401 is a transciever.
Most of the 2.4GHz transceiver I've looked at are
proprietary and different in the protocols and frequencies they use in
the 2.4GHz band unless you specifically go for Bluetooth or Zigbee for
example.
Have a look at the Atmel ATR2406. It doesn't have
a protocol built into the transceiver as does Nordic and Chipcon so you
are just sending and receiving bytes but the power out and sensitivity
are both very good so it might be better if you might need to go some distance.
Also the demo boards are good with a good basic design with an ATR2406
hooked up to a ATMega88.
Dave Pallant
Promethean Technologies Group Ltd and or associated and or subsidiary companies�:
The views expressed in this communication may not necessarily be the views held by Promethean Technologies Group Ltd and or associated and or subsidiary companies.
This e-mail is for the exclusive use of the addressee(s). Unauthorised disclosure, copying or distribution is prohibited.
This e-mail message has been swept for the presence of computer viruses.
Promethean Technologies Group Ltd and or associated and or subsidiary companies�accepts no liability for any loss resulting from this email transmission.
This email has been checked by the e-Sweeper Service
