RE: [AVR-Chat] Reading and writing 16-bit registers
2005-07-18 by Larry Barello
Both constructs are equivalent. One thing you *do* have to pay attention to: Make sure your access is non-interruptable as the temporary register used to hold the high byte can be clobbered by an interrupt handler doing a word access (there is only one temp register...) I must admit that I don't pay attention to my own caveat... I better go change that!
-----Original Message----- From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com]On Behalf Of Chuck Hackett Sent: Sunday, July 17, 2005 6:43 PM To: AVR-Chat@yahoogroups.com Subject: [AVR-Chat] Reading and writing 16-bit registers In looking at the instructions generated by WinAVR(gcc) I take it that: // Set timer counter to 0xC180 = 49,536 TCNT1H = 0xC1; TCNT1L = 0x80; LDI R24,0xC1 Load immediate OUT 0x2D,R24 Out to I/O location LDI R18,0x80 Load immediate OUT 0x2C,R18 Out to I/O location Generates the functionally identical (to my AVR inexperienced eye) code as is that generated by: TCNT1 = 0xC180; LDI R24,0x80 Load immediate LDI R25,0xC1 Load immediate OUT 0x2D,R25 Out to I/O location OUT 0x2C,R24 Out to I/O location Do all/most AVR compilers do this correctly, i.e.: write the high byte first? I've noticed that I've seen the first form used more often than the second. Assuming I stick with WinAVR, the second form seems clearer but is it bad coding style/practice? If there's no style/practice problem with the second form, can I always use it, or are there 'gotchas' in some cases? ... seems the world is filled with 'special cases' :-) Cheers, Chuck Hackett "Good judgment comes from experience, experience comes from bad judgment" 7.5" gauge Union Pacific Northern (4-8-4) 844 http://www.whitetrout.net/Chuck Yahoo! Groups Links
