2005-07-03 by Roy E. Burrage
Johnathan,
ESD protective devices (wrist straps, mats, chairs, etc.) have a 1M
resistor in the drain wire to bleed off the charge built up in a work
area. I've seen these work well even for women wearing pantyhose and
polyester clothing...not that we really want to test them to that extent
all the time, they do work. With this in mind, if you have a few
hundred ohms in parallel with your output you'll probably be okay.
The only time I ever saw a problem with the 1M resistors was when a
customer had their ESD grounding system connected to the same earth
ground as the machinery on the production line. When they had a motor
short to ground the ladies on the assembly line got a bit excited...and
they ran a separate ground line the same morning. It wasn't enough to
do harm to them but they were able to feel a tingle.
If you're going to do a lot of work with ESD as a major concern, it
might be wise to invest in an electrostatic voltmeter. A butane
charcoal lighter can also make a good ESD generator...but drain the
butane first.
REB
Johnathan Corgan wrote:
>I have an application where I need to use an ATmega8 port pin to apply
>bias current to a PIN diode RF switch. 10ma is all that's needed, which
>is no problem. However, the side of the RF switch that is being
>supplied current is connected to a mobile vehicle receiving antenna. My
>concern is that static build up on the antenna whip during motion will
>pose an ESD risk to the ATmega8.
>In practice, the antenna will have a DC resistance to ground of only a
>few hundred ohms, so I'm certain this will be enough to drain off any
>long-term accumulation, but is this sufficient?
>I know the pins have ESD protection diodes. I've never given them much
>thought before so I don't know if how effective they are at dealing with
>this sort of environment.
>I'm probably being overly careful. I suppose I could put a buffer
>between the I/O pin and the RF switch bias input, so the (cheap) buffer
>would get toasted before the (more expensive to repair) ATmega8. But is
>this even worth worrying about?
>-Johnathan
