AVR-Chat
Jumptable
Jumptable
2005-05-17 by Paul Maddox
All,
 Is it possible to impliment a jump table based on the value read from an IO
port?
What I want is to have a 8 routines, and when the value from a port is read
(3 bit value) it jumps to the appropriate routine, I want to avoid CMP and
BREQ if possible as I need a constant length for this, using multiple
CMP/BREQs would result in a variable excution time.
Oh, I'm doing this in assembler....
Any thoughts?
Paul
Re: [AVR-Chat] Jumptable
2005-05-17 by Leon Heller
Sent: Tuesday, May 17, 2005 11:31 AM
Subject: [AVR-Chat] Jumptable
All,
port?
Any thoughts?
I've not actually done it but it should be quite easy: something like using the ICALL instruction after setting the Z registers to the start of the jump table and adding the input value to ZL. It's actually more complicated than that, but you should get the idea.
Leon
Leon,
Thanks, I hadn't spotted that in the instruction set.
Just looking at IJMP, it may be simpler to use, no pushing/pulling from the
stack and its 1 less clock cycle (speed is king)...
Paul
To: <AVR-Chat@yahoogroups.com>
Sent: Tuesday, May 17, 2005 12:05 PM
Subject: Re: [AVR-Chat] Jumptable
  To: AVR-Chat@yahoogroups.com
  All,
IO
  port?
read
  Any thoughts?
Leon
Leon Heller
2005-05-17 by Zack Widup
On Tue, 17 May 2005, Leon Heller wrote:
>   All,
>   port?
>   Any thoughts?
> Leon
Yes, I've done it that way (in assembler).  I'll have to dig for the
sample code if you want it.  One thing to do is to make sure you mask off
all but the 3 bits you're going to add to the ZL register.  Otherwise it's
possible to end up some place you have no idea where.
Zack
Zack,
i'd like to see it, if you don't mind, thanks.
hehe, that seems to happen to me a lot :-)
Paul
Re: Jumptable
2005-05-17 by leon_heller
--- In AVR-Chat@yahoogroups.com, "Paul Maddox" <P.Maddox@s...> wrote:
> Leon,
from the
I've just written a simple jump table program using ICALL:
  .include "tn2313def.inc"
     .def	temp=r16
     .cseg
	 .org	0
	 rjmp	reset
reset:
	ldi		temp,low(RAMEND)
	out		spl,temp
	ldi		temp,$03
loop:
	rol		temp
	ldi		zl,low(jump_table)
	ldi		zh,high(jump_table)
	add		zl,temp
	icall
	rjmp	loop
jump_table:
	rcall	zero
	ret
	rcall	one
	ret
	rcall	two
	ret
	rcall	three
	ret
zero:
	ret
one:
	ret
two:
	ret
three:
	ret
Change temp within the loop using the simulator to check that it
works.
Leon
Re: Jumptable
2005-05-18 by Don Kinzer
--- In AVR-Chat@yahoogroups.com, "leon_heller" <leon.heller@d...>
Your jump table would be better if it consisted only of addresses as
opposed to the call/return.  That saves both time and space.  I use
the GNU assembler (comes with gcc) but the idea is the same.  You'll
just have to convert to the Atmel way of doing things.
Also, unless you can guarantee that the table doesn't cross a 256-byte
boundary you need to propagate the carry to the high byte.
Depending on what registers you have available, this code can be made
shorter and more efficient.  This is written using gcc register
conventions.  In particular, r0 is a temporary register and r1 is
always zero.  This code also assumes that the index value (in r24) is
never more than 127.
  ldi  r30, lo8(jmpTable)
  ldi  r31, hi8(jmpTable)
  add  r24, r24
  add  r30, r24
  adc  r31, r1
  ld   r0, Z+
  ld   r31, Z
  mov  r30, r0
  icall
; this table contains the program memory addresses of the specified
labels
jmpTable:
  .word	pm(one)
  .word pm(two)
  .word pm(three)
  .word pm(eight)
IAR - Anyone ?
2005-05-18 by Lasse Madsen
Hi All,
I'm trying out IAR's embedded workbench version 3.2A for the first time
and I've stumbled upon some questions which i hope you can help me with.
1)
when you write:
printf("Hello World");
It seems (or so i think) that IAR stores the string in RAM rather
than
in flash why is this and how can it be changed ?
2)
How do you store variables in flash ?
writing:
const char buffer[]="Hello World";   // is this stored in flash ?
__flash char buffer[]="Hello World"; // this is stored in flash
3)
If I make a long (1024 bytes) string (array) in flash:
__flash char string[1024]={...alot of data...};
And I want to print this to the serial port I do this:
printf("\r\n%s",string);
But it does not work...
So I though I needed a pointer to it...
char __flash *ptr;
ptr=&string[0];
printf("\r\n%s",ptr);
This didn't work either !?
4)
It seems that in the manual there's a function called:
printf_P for printing from flash but which file must I include to use
this printf function ? I cant seem to find it?
Best Regards
Lasse Madsen
Re: IAR - Anyone ?
2005-05-19 by John Mann
Lasse;
I am new to the group, but fimiliar with the IAR EWB.  I currently
have a system I am working on in which I have placed data in both
the FLASH and EEPROM on an MEGA128. If you look at the manual and
help file for the IAR compiler, they describe multiple ways of
forcing data to either the FLASH (ie code) memory or the EEPROM if
there.
Example __flash char Hello {"Hello World"};
The above example should put the constant string into flash memory.
Have a nice day.
John
--- In AVR-Chat@yahoogroups.com, "Lasse Madsen" <lasse.madsen@e...>
wrote:
> Hi All,
time
with.
> 1)
> when you write:
> than
> 2)
> writing:
> 3)
> char __flash *ptr;
> ptr=&string[0];
> 4)
use
> Best Regards
> Lasse Madsen
