AVR-Chat
uIP "applications"
uIP "applications"
2005-04-20 by Chuck Hackett
Is anyone familiar with uIP?  I have downloaded the AVR port from:
http://www.laskater.com/projects/uipAVRgettingstarted.htm
and the small test application compiled and ran first time (trial version of
ImageCraft compiler but it also has #ifdef to support gcc).  The only change I
had to make was to reduce a buffer declaration to get it to fit in the SRAM on
an ATMega16.  So far I'm impressed.  One of the main reasons I tried it was that
it supported the ASIX Ethernet controller chip that's on the board I have.
Question: I'd like to compile in two "applications" as uIP refers to them but
I'm a bit confused about how to structure the main module so that each has the
correct contexts.  The two I want to compile in are the SMTP and Web Server
modules.  I don't want you to write the code for me, I just need some guidance
in how one compiles in two "applications" as opposed to one:
- setting them up so they each have the appropriate context globals)
- routing uIP events to the appropriate application
Any pointers would be appreciated ... single indirection only, let's keep it
simple :-)
Cheers,
Chuck Hackett
"Good judgment comes from experience, experience comes from bad judgment"
7.5" gauge Union Pacific Northern (4-8-4) 844
http://www.whitetrout.net/Chuck
