AVR-Chat
How to manually trigger a counter interrupt
2005-04-17 by arhodes19044
I am using TC1 to time milliseconds for a real-time clock.  I am using
a prescale of 1 and count to 16,000.  I could use a larger prescale,
but this way I can adjust the clock speed slightly.
I also want to manually trigger one of the other counter channels
(OC1C) to cause the execution of another separate interrupt.
The ATmega docs say that  I just need to raise the OCF1C in ETIFR and
then the interrupt will be executed (on the next clock tick, I
suppose).  Of course the interrupts need to be globally enabled.  I
did not set the OCIE1C bit because I do not want it automatically
counting.  When I tested the function, it did not seem to   trip the
interrupt.
What do I do to get this technique to work?
-Tony
Re: How to manually trigger a counter interrupt
2005-04-18 by Don Kinzer
> and then the interrupt will be executed (on the next clock tick, I
> suppose).
As I read it, OCF1C is a flag that is set when the timer meets certain
conditions and if the corresponding interrupt is enabled, the interrupt
will occur.  You can reset the flag by writing a 1 to it, just like
(most of) the other such flags.
You can force an output compare (FOC1C) but I think that that does not
generate an interrupt.  The docs say that that doing so does not assert
OCF1C.
Don
2005-04-18 by arhodes19044
Yes, I would have thought that setting FOCn _should_ initiate
everything an output compare would do.  But the docs definitely say
it will not make an interrupt.  I guess it will just do whatever is
programmed for the OCn pin.
I tried setting the OCF1C bit but an interrupt did not occur.  I
tried the same with OCIE1C set (this enables the output compare
match interrupt.  And I still did not seem to get it to work.
I would have thought I covered all the operating conditions....
-Tony
I
> > suppose).
certain
interrupt
like
not
assert
> OCF1C.
> Don
