Hi!
Try LM358 - it should work fine in this aplicattion
(2opamp wersion of LM324).
If you realy need negative supply you my use one uP
pin to directly drive a cap in voltage converter. I
use it to get negative contrast voltage for LCD
displays. By changing duty cycle is posibble to
"control" output voltage.
Grzesiek
Do you Yahoo!?
Yahoo! Personals - Better first dates. More second dates.
http://personals.yahoo.com
