Re: [AVR-Chat] Mil Std 1553
2005-03-18 by Jim White
Thanks. I just looked at DDC and have posted them a question on the minimum number of I/O lines needed to interface Their ACE to a embedded controller. The data sheet would indicate about 40 - as in a PCI bus or the like. A nonstarter for us. What we really need is a serial to 1553 converter sort of like the simple serial to RS-422 chips on the market, but which does the protocol as well. Or even the CP2101 and similar RS-232 to USB converters. Jim
>Jim White said: > > > > Anybody know of a Mil Std. 1553 implementation on something like a > > M128? Looks like there are transceiver chips out there but you have to > > do the protocol in your software ?? > >Jim, > >I seriously doubt anyone is doing this directly in a microcontroller (or >any other processor for that matter). You can buy specialized chips to do >it from a number of vendors, but they are usually expensive. I know that >at least Actel has a soft IP core to put in an FPGA which has the >advantage of providing radiation hardness too. And it would certainly be >doable in VHDL or Verilog if you have the time to develop it yourself. > >Mike W4LNA > > > > > > >Yahoo! Groups Links > > > >
