AVR-Chat
RE: [AVR-Chat] ADC tips?
2005-03-11 by Stuart Whelan
>>The pots are 3pin pots with pin 1 connected to GND, pin 3 to AREF and
>>pin 2 to the ADCn.
>Very naughty!! From the M8 manual:
Eek! Burn the witch!
>VREF can also be measured at the AREF pin with a high impedant
>voltmeter. Note that VREF is a high impedant source, and only a capacitive
>load should
>be connected in a system.
Um, I did a google search and couldn't see anything on turning a resistive load (which is what I am guessing a variable resistor is) to a capacitive load. Could you offer any advice here?
I found an article that talk about using Pots on the Mega8 and they look like they are pretty raw?
Thanks for the heads up!
Stuart Whelan.
