Re: [AVaRICE-user] I killed the device JTAG ID
2005-01-20 by Russell Shaw
E. Weddington wrote: > Russell Shaw wrote: > >> >> Adding new commands into gdb that you can use from the gdb shell and >> call up a help page isn't hard. I've added commands to set and >> show fuses and lock bits, and reset the device sanely. I'll add some >> others such as to upload code out the device etc. >> >> To add a simulator or another target is easiest just to look at the >> others that are already in there to see how they fit in the gdb >> framework, and didn't look very hard at all. >> >> All programming devices such as stk500, avrisp, and freeware ones >> could be controlled from gdb. > > That would be fantastic! > > I wonder, though, what about the parallel port programmers, such as > found in avrdude? I haven't done parport programming in linux yet, and i haven't seen any parport stuff in gdb (tho i haven't specifically grepped for it). I could probably add the capability, but it would be something done later rather than sooner. >> I've been thinking of making a gtk frontend for gdb with user >> configurable buttons and things that are useful for embedded targets, >> but i have to fit it in between paying work for next few weeks:( >> > Pretty ambitious, but I would certainly welcome something a little > better than Insight; as long as your gtk frontend could be built for and > run on a Windows host as well. In fact, Colin and I were just talking > about this very thing offline.... There's lots of gtk apps ported to windows. >>> It would be a Good Thing to get a simulator into the GDB tree, one >>> that can handle running the GCC test suite. There's been a lot of >>> work recently in getting the GCC test suite working for the AVR >>> (using simulavr). >>> >>> Interesting possibilities... >> >> >> I've looked into simulavr before but was always put off by the >> tediousness of connecting gdb to it with a unix socket. I'll >> probably get it into gdb sometime too. >> > > FYI, simulavrxx has somewhat superseded simulavr. They are both located > on the same "SimulAVR" project on Savannah. simulavrxx has more > capabilities, but the GCC test suite for the AVR is being put together > by Bjoerne Haas using simulavr. Problem is that gdb doesn't seem to have any C++ stuff, and i like C hacking anyway. I'll have to resurrect simulavr as straight C. I wouldn't worry about the peripherals, just the core would be important, with probably some user commands to manually trigger an interrupt.
