AVR-Chat
Re: [AVR-Chat] Radio servo for analogue indicator?
2004-12-15 by Leon Heller
From: "Bernd Felsche" <bernie@innovative.iinet.net.au>
To: <AVR-Chat@yahoogroups.com>
Sent: Wednesday, December 15, 2004 4:06 PM
Subject: [AVR-Chat] Radio servo for analogue indicator?
> I'm considering all sorts of low-power options for providing an
> analogue indication (moving needle or bar). Typical ammeters draw
> current and the quantity I want to indicate isn't directly available
> as a current... it's number-crunched. Scale will be semi-log.
> At first, I looked at small stepper motors but they're simply
> over-kill.  During my search, I've stumbled across radio-control
> servos... which are quite popular in robotics and the driving
> technology is certainly well known in AVR circles.
> The question is; has anybody used these servos for instrumentation?
> The accuracy doesn't need to be high; it only needs to provide an
> at-a-glance feel for the operator. The indicator only needs to be
> "accurate" at one point, which could be calibrated at "boot time".
> I expect the AVR controlling the servo to have a table of position
> vs value... with linear interpolation for points inbetween.
> Any pointers to useful information such as steady-state current,
> holding torques, etc will be appreciated. I Googled but got around a
> million hits... or none.
How about a voltmeter driven with PWM, or a simple DAC?
I think that the Kawasaki Hayabusa motorbike uses servo motors for the
speedo and rev counter. When the ignition is switched on and the bike does a
self-test, both sets of needles rotate rapidly for a few seconds.
Leon
2004-12-15 by Bernd Felsche
/"\ Bernd Felsche - Innovative Reckoning, Perth, Western Australia
\ /  ASCII ribbon campaign | I'm a .signature virus!
 X   against HTML mail     | Copy me into your ~/.signature
/ \  and postings          | to help me spread!
2004-12-15 by KEN HUNT
If you want low power how about a graphical LCD
display (mobile phone display for example) emulating a
needle or a moving bar? A Nokia 3310 LCD (for example)
would give you 48x84 pixels for not a lot of money.
ken
 --- Bernd Felsche <bernie@innovative.iinet.net.au>
> providing an
> ammeters draw
> directly available
> semi-log.
> they're simply
> radio-control
> the driving
> instrumentation?
> to provide an
> only needs to be
> at "boot time".
> table of position
> inbetween.
> but got around a
> Western Australia
> ~/.signature
> Make a clean sweep of pop-up ads. Yahoo! Companion
> Toolbar.
> Now with Pop-Up Blocker. Get it for free!
http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/dN_tlB/TM
>     AVR-Chat-unsubscribe@yahoogroups.com
___________________________________________________________
Win a castle for NYE with your mates and Yahoo! Messenger
http://uk.messenger.yahoo.com
AW: [AVR-Chat] Radio servo for analogue indicator?
2004-12-15 by Gert Mueller
Bernd,
those servos draw quite a lot of current - especially while they move,
are we talking of some 200 mA or so - in that respect a classic ammeter
would be the better choice I guess.
Cheers, Gert Mueller
Datentechnik Dr.Gert Mueller GmbH
Diezstraße 2a,   D-53113 Bonn
Tel: +49-228-217297 Fax +49-228-261387
EMail: info@stepwalk.de
Homepage: www.stepwalk.de
> Make a clean sweep of pop-up ads. Yahoo! Companion Toolbar.
2004-12-15 by Jeffrey Engel
Have you considered LED's?  If they would work in your
application, they'd be easier to prototype, respond
more quickly and probably less expensive.
Several times, I've thought about using a stepper as a
Tach indicator, but the LED's response speed is too
large an advantage.  An RC servo would be even slower.
The one big disadvantage LED's have is not being able
to be seen in strong light.
Jeff Engel
> providing an
> ammeters draw
> directly available
> semi-log.
> they're simply
> radio-control
> the driving
> instrumentation?
> to provide an
> only needs to be
> at "boot time".
> table of position
> inbetween.
> but got around a
> Western Australia
> ~/.signature
> Toolbar.
Happiness is - positive intake manifold pressure.
Do you Yahoo!?
Read only the mail you want - Yahoo! Mail SpamGuard.
http://promotions.yahoo.com/new_mail
2004-12-15 by Mike Murphree
> current and the quantity I want to indicate isn't directly available as
At the risk of showing my age, does no one remember moving coil meters
anymore?
See: http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/galvan.html#c1
> "accurate" at one point, which could be calibrated at "boot time". I
> expect the AVR controlling the servo to have a table of position vs
You should be able to create any sort of scale you want with the AVR
driving it.  They typically require very little current.
Mike
2004-12-16 by Bernd Felsche
> > draw current and the quantity I want to indicate isn't directly
> > available as a current... it's number-crunched. Scale will be
> > semi-log.
LED's are in use at the moment, but useless under nominal lighting
conditions. Bright daylight.
You got it in one.
> > semi-log.
Two factors: The LCD requires much more glue to drive and secondly
most LCD give up the ghost at the ambient operating temperatures
that may exceed 45 degrees C.
2004-12-16 by David Kelly
> does a
The Hayabusa is a Suzuki.  :-)
These days most vehicles use electronic meters because the electronics
are less expensive and more reliable than mechanical.
If one wishes a simple indicator then R/C servos would be a good
choice. "Real" meters are expensive!
As nothing but an indicator one doesn't need any holding torque other
than existing internal friction. As for power and current consumption
once one has the desired indication then simply quit driving the servo.
It will stay put.
David Kelly N4HHE, dkelly@HiWAAY.net
Whom computers would destroy, they must first drive mad.
> anymore?
Sure do!
The indicator is for a "power balance" display in a solar car.  It
will be subjected to vibration as well as high ambient temperatures.
IIRC, the moving coil meters don't typically like that sort of
thing.
I'm not sure of all the options available to drive one to display
the quantities (PWM would depend on the mechanical response) ... and
finding one with a highly-visible needle is another task altogether.
Response time isn't that critical. As long as the full scale can be
traversed in about half a second or less, that's fast enough. I
intend to only show a moving average over one or two seconds anyway,
otherwise the display gets "too busy", causing the driver to make
many adjustments over time which aren't really necessary.
Re: AW: [AVR-Chat] Radio servo for analogue indicator?
That's why I wouldn't move it very often, nor far, most of the time.
The load against which it'd move would be close to zero.
Any idea of the current draw if the position isn't changing?
That's the sort of information I'm looking for.
Except the environment (solar car) isn't very friendly to it; and
it's almost nominal operating conditions for the servo.
2004-12-16 by Jeffrey Engel
Bernd;
IIRC, the RC servos take a 0.5ms to 1.5ms pulse input
at about TTL levels.  If you're really strapped for
power, you could always power it down until the
reading needs to change.
The pointer could be something simple made from
pastic, like a disk with the 'needle' drawn on with a
marker.  Naturally, once you're convinced it will work
you could fab up something more elegant.
Sounds like a good match for your application.
Disclaimer: I'm not into R/C and going from an
increasingly faulty memory. . .
Jeff Engel
> they're simply
> and the driving
> circles.
Do you Yahoo!?
Yahoo! Mail - Find what you need with new enhanced search.
http://info.mail.yahoo.com/mail_250
Make that 'plastic'. . .
Jeff
> a
> work
Do you Yahoo!?
Yahoo! Mail - 250MB free storage. Do more. Manage less.
2004-12-16 by David D. Rea
There are a variety of very bright daylight-visible LEDs on the market.
Some output hundreds of mcd in only tens of milliamps.
Consider this option - arrange six high output bi-color (red-green) LEDs
in a line. Use the PWM capability of the MSP430 to drive each of them.
As the indicator "rises", first the LED begins to glow green, then
becomes a brighter green, then the PWM begins to introduce red. As more
red is proportionally added, the color changes from green to yellowish.
At 50/50, the LED appears yellow. Then, as the indication continues to
rise, the light begins to appear more and more orange, then red.
This would have sort of a "VU meter effect" and would be very good for
at-a-glance readings. All functionality could be achieved on-chip.
A quick Digi-Key search returns a high-output red/green LED in a 5mm
case, the Lite-On LTL-293SJW. It outputs 90mcd red, 40mcd green -
intensity will look about the same due to varying spectral sensitivity
of the eye when both are run at 20mA. They are $0.37 each and there are
thousands in stock - might as well pick up a few and try them. At that
price, even if it doesn't work, it's not much invested!
Dave
Whoops...thought this was posted in my MSP430 forum! My bad!
ifdef "Re: [AVR-Chat] Radio servo for analogue indicator?"
#define MSP430 AVR
endif
Dave
> Dave
2004-12-16 by Kathy Quinlan
> #define MSP430 AVR
> endif
> Dave
Lol is ok mate, would you share the link to the MSP list ? as I would
like to join one day as I have a stack of MSP's sitting here, just never
had the chance to play with them :(
Kat.
K.A.Q. Electronics	Website: www.kaqelectronics.dyndns.org
IM: Yahoo: PinkyDwaggy  MSN: katinka@kaqelectronics.dyndns.org
For Everything Electronics     Phone: 0419 923 731
If your pulse timing varies or the servo is worn or cheap then it will
"hunt" while not moving and consume a lot of current.
On the other hand once its in the position you desire then not only
quit driving the position pulse but remove the power entirely from the
servo. It will stay where you left it and require a modest amount of
force to budge.
IIRC the position pulse was 1.0 ms to 2.0 ms every 10 ms. Then again
there were 7 channel analog transmitters and there is only room for 5
if I remember correctly. The servo is quite forgiving about the 10 ms
part altho you have to keep sending the pulse until it reaches the
desired position.
It's another yahoogroup - just go to http://groups.yahoo.com/ and search
for "msp430" - I picked the one with the most members (over 2000)
figuring it'd be the most active...
Best Regards,
Dave
> > #define MSP430 AVR
> > endif
> > Dave
> Regards,
> Kat.
2004-12-16 by Gert Mueller
>most of the time.
The idle current of common R/C servos is somewhere around 10 - 15 mA.
For detailled info you might check the site www.graupner.de (servo
manufacturer) It's in German - but that shouldn't be a big issue for you
;-) right ?
> >most of the time.
> mA.  For detailled info you might check the site www.graupner.de
> (servo manufacturer) It's in German - but that shouldn't be a big
> issue for you ;-) right ?
Depends on the time of day! :-)
Oooohhh the choice of servos... 4.3g, idle current drain 5 mA. Nice
and light. And digital servos... a bit heavier in both respects as
well as price.
I like the idea of being able disconnect power to simply hold the
position.
It's a whole new world; I'll have to visit an R/C model shop and see
what's available locally.
2004-12-16 by Ken Holt
I thought I might chime in here re LED brightness:
The newer "ultra" bright LEDs, in the 3-7000 mcd range
and can be seen in most daylight conditions when placed
in a dark background or hooded arrangement.  They are still
moderately expensive for the very good ones, about a buck for
green, blue, or white.  Red and yellow LEDs have been very bright
and cheap for some time.  There are no common bi-colors of the
ultras, as yet, and the old red-green are very poor, the green half
is usually dim and yellowish.
Ken
> becomes a brighter green, then the PWM begins to int   roducered.Asmore
> rise, the light begins to appear       moreandmoreorange,thenred.
> Dave
Here's an on-line demo using an R/C servo that I
stumbled across while looking for something else.
He even has a goofy-looking green pointer hooked to
it!
http://www.ace-lab.com/SCADA/robot.html
HTH,
Jeff Engel
Do you Yahoo!?
Meet the all-new My Yahoo! - Try it today!
http://my.yahoo.com
2004-12-16 by Dave VanHorn
>it!
Cool! Servo wars.
Apparently I got on at the same time someone else did, or their control
loop is way whacked.
Dave,
When I 'researched' it, there was a significant delay
between control movement and response but seemed
pretty good other than that.
You probably weren't the only person checking it out.
Jeff Engel
> >it!
> Cool! Servo wars.
Do you Yahoo!?
2004-12-16 by Jim Wagner
The lag time is quite long but it worked for me.
Jim
On Thu, 16 Dec 2004 16:28:38 -0500
> >it!
> Cool! Servo wars.
> their control
>   ADVERTISEMENT
> To visit your group on the web, go
> to:http://groups.yahoo.com/group/AVR-Chat/
> To unsubscribe from this group, send an email
> to:AVR-Chat-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to the Yahoo! Terms
> of Service.
The Think Different Store
http://www.thinkdifferentstore.com/
For All Your Mac Gear
RE: [AVR-Chat] Radio servo for analogue indicator?
2004-12-17 by wbounce
How about using a speaks and tones. An AVR chip could more than handle
that.
From: Bernd Felsche [mailto:bernie@innovative.iinet.net.au]
Sent: Wednesday, December 15, 2004 7:52 PM
To: AVR-Chat@yahoogroups.com
Subject: Re: [AVR-Chat] Radio servo for analogue indicator?
> anymore?
Sure do!
> See:
The indicator is for a "power balance" display in a solar car.  It will
be subjected to vibration as well as high ambient temperatures. IIRC,
the moving coil meters don't typically like that sort of thing.
I'm not sure of all the options available to drive one to display the
quantities (PWM would depend on the mechanical response) ... and finding
traversed in about half a second or less, that's fast enough. I intend
to only show a moving average over one or two seconds anyway, otherwise
the display gets "too busy", causing the driver to make many adjustments
/"\ Bernd Felsche - Innovative Reckoning, Perth, Western Australia \ /
Yahoo! Groups Links
